Question about Panasonic AG-DVC10 Mini DV Digital Camcorder
Panasonic AG-DVC10 Is it possible to order the power/rec start stop switches from you that you've replaced on these models? chazebs@bellsouth.net
  • 3 Answers
There are eight separate parts that make up the DVC10 power switch assembly. Total cost for these is about $48 from Panasonic parts or authorized distributors.
Cameras that do not turn on usually do not require replacement of the switch parts, since the problem is on the main board or power/battery assembly.
Posted on Mar 12, 2009
Hi - I have a panasonic ag-7330 SVHS deck. It lights up but does absolutely nothing. The Video Rec Servo light is blinking constantly. Any ideas?
It could have a timer record present that needs to be cleared. Otherwise it could be the mode switch playing up. But that too can be caused by physical damage inside the unit, thus setting the mechanism in the wrong position. In other words it thinks it is in record mode when it's not!
Aug 24, 2015 | Panasonic AG-7330 S-VHS VTR PAL w/...
Do you repair camera Panasonic P2,no output in LCD
We do repair the models above. We order parts from Panasonic.
Mar 08, 2010 | Panasonic AJ-P2COO8HG for AG-HVX200...
Camera says it's taping but video not visable
clean the video heads - either a cleaning tape or a good hand cleaning by a qualified tech.
Mar 04, 2009 | Panasonic AG-DVC10 Mini DV Digital...
Panasonic AG-DVC10P zoom is stuck on max...
most likely cause of this problem is a stuck or defective zoom control. I have seen this one or twice. you may be able to disassemble the camera and free the zoom control if it is stuck, but it also may need to be replaced.
Aug 27, 2008 | Panasonic AG-DVC10 Mini DV Digital...
Panasonic DVC!)
typically, repair for the DVC10 (replacement of the cam/vcr and record start/stop switches) is around $125.00.
May 06, 2008 | Panasonic AG-DVC10 Mini DV Digital...
Problem with recording
this problem is caused by defective power and record start/stop switches. they are still available from Panasonic.
Jan 21, 2008 | Panasonic AG-DVX100A Mini DV Digital...
Panasonic AG-DVC10 Startup Issue
Most likely cause for this problem is defective power switch and defective record start/stop switch. The DVC7, DVC10 and DVC15 all use similar switches, and I have repaired all three.
Jan 16, 2008 | Panasonic AG-DVC10 Mini DV Digital...
Ag-dvc7
most likely cause of this problem is loose or dirty cable connections to the video head or mechanism in the camera. get a tech to disassemble the cam and check the flex cables connecting the main board to the mechanism. same fix is good for AG-DVC10 and AG-DVC15.
Nov 14, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Vcr plays ok, but will not rew or ff
either bad mode select switch or bad sensors. my bet would be bad mode switch( pull apart and clean contacts.)
Mar 07, 2007 | Panasonic AG-720 VCR
Panasonic AG-DVC10 Mini DV Digital Camcorder Logo
131 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
