Question about Coffee Makers & Espresso Machines
Water spewing out of the steam pipe on my Starbucks Barista
As soon as my Starbucks Barista warms up is starts to spew water out of the steam pipe and I cannot shut it off.
  • evairene Mar 25, 2009
    Our steamer at the Saeco Odea isn't tight any more. Tried descaling, but that didn't help. Meanwhile I got so bad, the machine doesn't get any water for the espresso any more because it all flows out of the steamer.
  • 69 Answers
U must change the guarnition of the steam rubinet
Posted on Jan 08, 2009
Water spewing from piping near the water pump
The water pump is most likely bad.They leak when they wear out.You need to replace it and check all your hoses make sure none of them are leaking.
Apr 02, 2014 | 2000 Mazda Familia
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
Water spewing everywhere pressure cooker
Happen to me cooking porridge when the mixture within the pressure cooker is too thick such that not enough steam is produced at ounce to get the cooker to seal itself. Add water if possible.
Jul 29, 2012 | Fagor 8 quart Duo Pressure Cooker
Water spewing from steam vent whenever I cook rice and I have measured accurately. It is a mess!
I found a solution to the spewing around the lid and through the vent.
The other day I placed the steamer tray in the top and then the lid.
The steamer "broke up" the bubbles -- no spewing out of the pot or mess -- I mostly happened with brown rice -- but the last 2 times -- not mess!!!!! Hope this helps someone else.
Apr 07, 2010 | Krups FDH212 10-Cup Rice Cooker
Not brewing shots, just spewing water out the top!!!
Yup, it sounds like you have a leak !  When the spoon is locked in place, the coffee is preventing (blocking) the water from flowing freely, and it simply finds an easier path, through a hole or loose fitting above the spoon... Depending upon your skill level, you may want to have a look inside the machine and you should be able to see where the leak is.  If it's a hole in a pipe/tube, the pipe/tube will probably need to be replaced (maybe it can be repaired...), and if it's a loose fitting, you can try to tighten it.  It might have come loose due to the vibrations from the pump. Another possibility is that you have a lot of scale built up in the system.  If you've never descaled your machine, you should do so regularly using coffee machine descaler or "CLR" available at hardware stores.  If you've ownded your machine for a while and never descaled it before, run the descaler 4 or 5 times to give it a good cleaning and then do so according to the instructions (I do mine every couple of months but I don't use my machine every day).  If you use unfiltered tap water, the scale will build up more quickly, specially if your local water is "hard".  Consider using filtered water to reduce the buildup of scale.
May 04, 2009 | Starbucks Barista Utopia
Water spews out drain when washer is draining
Call one of those sewer boys, partially clogged I would say.
Anymore drainage problems in the house.
To avoid costs could try to clean the water lock.
Ask price on before hand, avoid night weekend calls.
Apr 16, 2009 | Kenmore Washing Machines
No water flowing through steam wand
You might want to try draining the machine and filling it back up. There could be a number of different things wrong with your machine.
Mar 21, 2009 | Starbucks Barista Utopia
Starbucks barista machine steam valve leaks.
Hi Sammy,
I think you have to replace the steam valve and the gasket in it.
Best regards
/Mirran
Nov 07, 2008 | Starbucks Saeco Italia Digital Barista...
Coffee Makers & Espresso Machines Logo
210 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
