Question about Samsung DLP HL-P5663W 56" TV
TV shuts off with no warning and no apparent reason
My TV is 2 years old.. the first week I owned it , it would shut off after 40 minutes and if I turned it back on , it would shut off within 2 minutes..
It stopped this behavior and it has now suddenly reappeared.
I moved the TV to another room where it is not connected to any external speakers or receiver but connected to a HD box.. Now it stays on..
Could the receiver be overloading the TV causing it to shut off? It did not do this for 2 years and then suddenly started up again.. I did reboot it ( unplugged) several times and that did not help but moving it to another room and another HD box "fixed it"..
Any ideas?
    Sergeant:
    Champion:
  • 435 Answers
May be the receiver or the speakers are faulty. or may be short circuited causing the TV to shut down for safety ...
Posted on Jan 09, 2009
    Scholar:
  • 143 Answers
It's wather problem u need to chek it with a repair also chek that yr home voltage and tv needed voltage is proper or not also chek this things.. it's help u
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, to my view, a case of loose connection. Moving jarred the connection back into correct position. Another possibility is cold solder and/or heat related issue simulating a loose connection.
Corrective measure would be to open, clean and check connections and re-solder. Even if the unit is fully operational now, the knowledge that it has a dormant fault should not be left unattended.
Good luck and Thank you for using FixYa.
    Scholar:
  • 100 Answers
Open it up and clean it with a vacum cleaner, it might have accumulated dust and if your house is humid then it would be even worse you'll need to brush the boards and clean them well.
if your TV has a Fan inside make sure its working right. if it has a heat sink mounted on a chip make sure its contacting the chip. make sure you have enough ventalation behind the TV and on the sides.
if this happened too many times, you might have some of your chips deformed and damaged byond repair, that need replacement.
Posted on Jan 08, 2009
    Sergeant:
  • 378 Answers
Sometimes due to overloading or manytimes due to any of the component in your receiver getting overheated and so this problem occurs and the unit gets shut off.
  • 4,472 Answers
My first question would be what kind of surge protector do you have all of this hooked up to? It could have something to do with brown outs/ or fluctuation in power. Make sure you have a quality surge protector. I prefer monster power something with clean filter technology to keep the power consistent. If you need any further assistance please let me know. Also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
    Sergeant:
    Novelist:
  • 326 Answers
Yes this type of problem can occur.its much possible.this happens many a times.
Samsung 55" LED UN55D6003 Intermittently turns off and on...T/S help
DO NOT ATTEMPT ANY REPAIRS, CALL THE FACTORY PHONE NUMBER IN THE OWNERS MANUAL AND FIND OUT WHERE TO HAVE THE TV SERVICED, IF YOU ATTEMPT ANY REPAIRS THEY WILL VOID THE FACTORY WARRANTY. THIS IS CAUSED BY AN ELECTRICAL FAULT INSIDE THE TV, IT SHUTS DOWN AS A SAFETY FEATURE TO AVOID ANY FURTHER DAMAGE.
Dec 06, 2011 | Samsung UN Televison & Video
Samsung 6003 turns off and on by itself
Hello
You have posted to wrong place.
Regards
Ajay
Dec 06, 2011 | Samsung LN Cell Phones
My flat screen tv shuts off and standby led blinks 13 times.
Our $2700 less than 3 year old Sony LCD KDL-40XBR5 did the same thing 2 weeks ago. Sony was anything but helpful. They said to take it to a repair shop or we could send them $550 and they would replace it with a $800 set. Repairman says that it is a panel and the part has been discontinued by Sony. The 46" sets had the same problem and were recalled but not the 40" screen. We stopped on the way home and purchased a 40"
Jul 12, 2010 | Sony KDL-40XBR4 40 in. LCD HDTV
TV just shuts off on it own... Have a westinghouse LTV-27-W2 TV purchased in 2005. It's been shutting off for no apparent reason... I wonder if it's going bad or is it the power cord.
Most likely, a number of capacitors need to be replaced in the power supply on this set, OR possibly, there is a bad connection on a connection on the snubber capacitor in the power supply, near the SMT transformer--and I have seen this MANY times on westinghouse LCD sets. .
Oct 09, 2009 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Samsung HLM5065W DLP shuts itself off for no apparent reason
I just had the same exact problem. New bulb and all. Tech. said it was the Light Engine assemble was going bad. Here is some photos of the Light Engine.
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
Nov 22, 2008 | Samsung HLM5065W 50" Rear Projection...
My t.v. shuts off after a few minutes
try this link...it tells you what the LEDs indicate. Apparently the cover on the back is not sealed properly, my guess is that it is a fan not working properly or some other reason the set is overheating.
http://downloadcenter.samsung.com/content/EM/200604/20060404091311750/EN/3_sub.htm
Oct 31, 2008 | Samsung HL-S4266W 42" HDTV
Panasonic shutdown
That red light is actually a failure code. You will need qualified servicer to look at it. You should be able to get shop or inhome min fees as low as 50-75.00. You may, however be looking at a repair bill in excess of 3-400.00
Craig www.classtorations.com
Jun 07, 2008 | Televison & Video
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Dehumidifier keeps shutting itself off.
For some reason it is overheating and shutting itself off. There is a law that all electronics are supposed to have a point to where it automatically shuts off if it gets too hot from a malfunction or loose connection in the circuit board. It is to protect the consumer. You either need to take it to a tech or get rid of it. Get a new one.
Sep 13, 2006 | GE AHG40LA Dehumidifier
Samsung DLP HL-P5663W 56" TV Logo
21 people viewed this question
Henry  Thomas
Henry Thomas
