Question about ASUS K8N4-E Deluxe Motherboard
ASUS KBN-E MOTHER BOARD 754 processor 512mb ram
Not sure if you can help. My second computer does although receiving power does not power up floppy drive,hard drive or cd r/w from mother board. All component work when not connected to mother board, all fans work and system lights. Can you let me know if the board has most likely died or can I try something else. Thank you for any help. Colin
  • colin stanley Jun 03, 2007
    I had already tried your suggestions but thanks anyway.
  • Anonymous Aug 23, 2008
    Drivers Motherboard
Audio problem
Posted on Dec 01, 2009
    Problem Solver:
  • 6 Answers
Try plugging the drives into another computer to see if they actually work, ie read discs etc if they do then try swapping the power supply out of your computer.. if this doesn't work then I would say your motherboard is dead. Good luck
Posted on Jun 03, 2007
My computer it when I do the Ctrl+Alt+Del all it keeps doing is popping back up on the screen I can you help
The hard drive is not loading the operating system. If you have a floppy drive connected and there is a floppy disk in the drive, it won't boot. Remove the disk and try again. If you have no floppy drive connected, then your hard drive is no communicating with the mother board. This could be due to a disconnected power or data cable on the hard drive or the mother board end of the cable. If all the cables check out OK then your hard drive has gone bad.
Dec 20, 2015 | Computers & Internet
My computer cannot turn on the power, and i found a red led always on at the center near the rear portion of the mother board. is that something wrong with the mother board or just the supple power is...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
also check the Cmos battery and computer ram make sure they are securely seated
hope this helps
Jun 26, 2011 | Shuttle K45 Intel based barebone system...
Faulty Power Circuit board Short Circuit on Motherboard Malfunctioned circuit on mother board Faulty Motherboard, Power supply not working Power does not flow through the circuit board Faulty Circuit...
Test your power supply unit if the PSU units fans not working its faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error computer error a computer needs its connections continue its cycle and have an end to function
hope this helps
May 12, 2011 | IBM 41D2469 Motherboard
Mother board have power but no disply in
useing board for video i use card to save board live board maybe bad jim try card ok.
Apr 05, 2011 | Intel Motherboard
Was workin ok but no signal imput now
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
Mar 29, 2011 | Asrock K7VT2 Motherboard
5 socket mother board using 2800+ processor failed. Can i get a compatible mother board.
yes you can! compatible motherboards are cheap and easy to find for the socket 754 design compatible with your cpu. with prices going from anywhere from ~$50-$80. great places to shop include frys electronics, newegg.com, amazon.com and tigerdirect.com. when something like this happens to you its always a good idea to consider upgrading your computer as well you can find cpu motherboard deals anywhere from $100 to $200 with a huge boost in computing power. if you choose to go this route make sure your ram will work on the motherboard you are considering. goodluck
Mar 05, 2011 | AMD Athlon-64 2800 CPU and Mother Board...
Can I use P4 478 processor in K8V-MX mother board
You can not use intel ,It is a athlon platform Mother board.
Follow the link, and you can know every thing from here.Just click here.
Hope it will help you.
Regard's
Shibuda.
Dec 31, 2010 | ASUS K8V-MX Motherboard
My XPS 420 mysteriously quit working (odds are on the 18 month old pushing the power button on and off and on and off and... you get the picture) So the power button light was blinking amber. I replaced...
So. you replaced the power supply, was the computer working properly before you replaced the power supply? I am thinking that your motherboard is the issue. Usually when you get a blip of power and the fans only work for a second, it is usually a burned out motherboard. One can never be certain without looking at the unit first hand, but that is an educated guess.
You can try re-connecting the power supply leads to the motherboard and disconnecting all other hardware except for the hard drive. See if you have a hardware problem with you CD or your Floppy drive (if you have a floppy). If your secure in the fact that you have a good power supply now, this is an option.
Let me know what experience you have if you go ahead and try this procedure.
Brian
Dec 22, 2010 | Dell Computers & Internet
After starting the My computer fan is stop within a few seconds, S.M.P.S. is Working with good condition on other computer. The Power light of Mother Board is On
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? while your at it
clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making VERY sure there is no MOISTURE in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
hope this helps
hope this helps
Oct 07, 2010 | ASUS P4P800S-X Motherboard
ASUS K8N4-E Deluxe Motherboard Logo
6,416 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
