Question about Canon PowerShot A540 Digital Camera
Formating a new card for the Canon PowerShot A540
I have the Canon PowerShot A540. I do not have my manuel with me and I needed to insert a new card. However, I have forgotten how to format the card. The card is not locked, however, it says the card is locked. Help!
Thanks, findjetlag@rogers.com
  • findjetlag Mar 04, 2009
    Thank you so much for the solution. I've copied this for "the next time"!
  • 423 Answers
Here is how you do it.
1) press the menu button.
2) scroll right to the Setup Menu
3) scroll down to format.
4) scroll right to enter Format Menu
5) scroll up to Low Level Format.
6) scroll left or right to add a check mark.
7) scroll down to ok and press the function/set button.
Sorry no one got to you sooner. Hope this helps you, and thanks for coming to FixYa. Don't forget to rate my solution.
Rob
Posted on Mar 03, 2009
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
I have a canon powershot a540 bought used and i cant not format the memory card
Hi Hello,if your Digital camera and memory card can't format,try to my advice, you get out your memory card to your digital camera,and you can try to reformat your memory using your computer,if the memory card can't format throught using your computer,its mean your memory is need to replace new memory card. hope its work it,thanks
Jul 28, 2011 | Canon PowerShot A540 Digital Camera
Hi, My canon PowerShot A540 camera gives an error " Card locked" Memory card error. I tried switching off the lock, but it didn't help. The card does not get recognized while inserting it in...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
You also mention recovering photos saved on the card. If you actually did take pictures with this card (assuming it's a 2GB or less standard SD card, as 4GB SDHC was not designed for your camera), you may be able to recover the photos using recovery software. See this other link.
Jun 10, 2011 | Canon PowerShot A540 Digital Camera
I was trying to insert a new sdhc 4gb card in my powershot a540. Shows card locked error even if its not.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 19, 2010 | Canon Cameras
Cannon Powershot A540 SanDisk SDHC 4 gb I insert the card and receive a memory card error. Can't format
A 4 gb memory card is beyond the capacity of your Cannon A540. It is too large. I would stick with a 1 gb card in that camera.
May 28, 2010 | Canon PowerShot A540 Digital Camera
When i insert 4gb memory card into canon power shot s21s, camera is disabled. cannot take pictures
Your new 4GB memory card is the problem. The card would likely be an SDHC card (look on its front cover). Your A540 camera was designed well before the SDHC format came out, and your camera will not recognize it. Your camera can only use standard SD cards (2GB or less). Here's some from Amazon.
Feb 14, 2010 | Canon PowerShot A540 Digital Camera
Memory card locked
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Feb 07, 2010 | Canon PowerShot A540 Digital Camera
I'm looking for an owners manuel for canon powershot a540
If you are looking canon A540 user manual then get it from Canon Support.
If model number is different, let me know.
Dec 17, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot A540 Digital...Problem
To view the pictures on the computer, remove the card from the battery compartment and put it in a card reader connected to your computer.
Jan 01, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot A540 Digital Camera Logo
143 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
