Question about iRiver H10 MP3 Player
Iriver h10 when unplugged from maines or pc wont switch on when plugged in pc or mains battery has line through it apart from obviouse could anything else be wrong does not show up on pc as new item found so cant sync if not selling for spares is only option everything else is intact glass not broken
  • bear0625 May 08, 2009
    when i unplugged iriver from computer, the screen still display USB connected and i cannot do anything about it
  • 8,596 Answers
Reset
Reformat
Use Recovery Tool from iRiver website
Posted on Jun 26, 2008
Need to reboot iriver h10 cant delete songs
Ok , sorry it took me until now to answer , this is a very simple procedure and I promise it will fix your Iriver! All you have to do is go to main menu , scroll down to settings . Then go to additional settings and at the very bottom select " Database Refresh " . This will fully reboot your irvier H10 , and will flush anything harming your mp3 device .
Hope this helped :)
- Chris
Feb 15, 2010 | iRiver H10 MP3 Player
System files missing
I got this from another post:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Also go here for the firmware directly: http://iriverinc.com/support/hd/h10_5-6gb.aspx
Apr 13, 2009 | iRiver H10 MP3 Player
I fixed this problem for my mate, here's what I did:
hope this helps.
Here is for the Iriver H10 software:
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Take out the battery, wait a second, and put the battery back in.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For 20 GB MTP Models
  • Poke the "reset" button with a paperclip.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
Coping files from iriver H10 20 GB to pc
The USM trick allows you totreat your H10 as an external hard drive. Then it is easy to copy the musicback to your PC using explorer.
The details for the USMtrick are taken from mistic river.
http://www.misticriver.net/wiki/index.php/H10_Tips_and_Tricks/UMS_Trick
H10 Tips and Tricks/UMSTrick
From iriver Wiki, yoursource for everything iriver - a part of MisticRiver.
Jump to:navigation, search
Most people agree that theUMS trick is a great thing to know how to do. With it, you can transfer music,OR treat your H10 as a harddrive to put anything you want on. The UMS trickwill also allow you to use your H10 with virtually any OS.
5/6 GB MTP Models
1. Make sure your H10 is turned off anddisconnected from the computer.
2. Take out the battery, wait a second, andput the battery back in.
3. Turn on the hold switch (so that youdon't accidentally turn the H10 on all the way).
4. Plug the H10 into your computer.
5. Turn on the H10 while holding the"O" button.
6. You will see the message "UMSMode" if you have done everything correctly. You can now let go of the"O" button.
20 GB MTP Models
2. Poke the "reset" button with apaperclip.
5.Turn on the H10 while holding the "O" button.
6. You will see the message "EmergencyConnection" if you have done everything correctly. You can now let go ofthe "O" button.
UMS Models
UMS models do not need thistrick because they are always in UMS mode!
Sep 01, 2008 | iRiver H10 MP3 Player
Battery replacement-h10 20 gb.
follow this link http://www.videojug.com/film/how-to-replace-the-battery-on-the-iriver-h10 and it instructions.............feel free to rate the help
Jul 30, 2008 | iRiver H10 MP3 Player
Wont go to main screen
I had one of these for a while, before I finally got fed up with the crappy firmware and switched to Rockbox, an open-source firmware that is infinitely better than the default.
But if you do want the original firmware, go here: http://iriveramerica.com/support/mtpupdate/ for a step-by step guide to reinstalling the firmware. Be warned that I do believe your music will be deleted from the player, though.
Dec 24, 2007 | iRiver H10 MP3 Player
IRiver H10
Require more history 1/condition of H10 battery B4 this problem (blown Charger Fuse) occurred 2/perhaps battery condition severly depleted creating high current draw upon initial charge attempt 3/not certain if an circuit protection fuse exists in H10 4/Chk charger wiring for shorts bare contacts etc.
Nov 27, 2006 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
145 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
