Question about Canon imageRUNNER C3200 Color Printer
I have a ip4200 printer and rebooting the printer and the computer doesn't help. It seems as if the paper shoot may not be letting the paper down for printing. Any advice? Signed, Frustrated
  • 1,219 Answers
Is the paper when picked up got wrinkles on some side, like something is in his way?
remove ink crg, flip printer up side down to eject foreign material from paper path.Also use flash light and check for something stucked.
hope that helped.
also it could be that pick up roller has broken bushing
Posted on Jun 15, 2010
I cant get the printer to print. The middle orange light is flashing and the bottom green light when pushed does not change up . the computer says the paper is jammed but it is not. Hope you can help...
whats happened is the timing of the gears in the printer have been disrupted by not removing jammed paper correctly.
unless your well versed in repairing and retiming printers you need to take it to a reapir center to let them reset the timing cycle
Jan 13, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Error 5110 of ip4200 ?
Do you use a long USB cable or use a USB hub to extend the length of the connection? It seems to be a problem associated with communicating with the computer. Are there any other USB devices on the same USB bus? Try to make a short connection and shut the printer off. Reboot the computer then power the printer back on. This may reset it and bring it back to work.
Nov 27, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Paper jam- canon iP4200
Here is the repair manual. It covers everything involved in repairing the printer.
Nov 18, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Paper stops half way
Please check for torn piece in the carriage which is causing the error
Jul 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Please problem solve
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 11, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Prints too small
try the print settings for scalable to fit the page..remove the s/w from the computer for the printer, then re install it
Apr 14, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
No printing
If you are sure there is no paper jam,have you tried reseting the printer?
  • unplug the power cord for the printer.
  • press and hold the power button
  • plug the power cord in still holding down the power button
  • the power light should come on when it does release the power button
  • power on the printer like you normally do
hope this helps good luck
Nov 28, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon iP4200
Paper jam!!! UJO's in sight (unidentified jamming objects. At least thats where i would start. Get a torch, tweezers and go on a little itty bitty paper hunt, i am willing to bet you will find a jam of some size or sort. ook everywhere, it doesn't have to be big to cause probs.
Aug 24, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Ip4200 - printing issues!
Hi, Perhaps you can try: remove the USB connection of the printer; uninstall and remove all drivers of the Canon IP4200; reboot your PC; plug in your usb to the PC from the printer; power on your printer; let windows auto detect "New Hardware found"; let windows auto install drivers; test print. If after plugging in your usb and powering your printer Windows did not auto detect "New Hardware found", it's possible that your printer's usb cable is defective. If Windows auto detected the Canon IP4200 and auto installed all the necessary drivers but failed in the test print, repeat above steps but instead of auto install, use the original CD driver and not the new drivers (Let me choose which drivers I want". RESET - User manual is available from the Canon site. There are 2 versions, 1 is a Quick Start Guide in pdf and the other is a User's Manual (On-Screen). Both does not say anything about reset, however you may want to google "fix your own printer" and variations of resetting all sorts of printers are available. Some works, others are ... well you can always give it a try. Or in the On-Screen Manual,you can also try the Troubleshooting/Printing Does Not Start. Another thing that you can try is installing the printer in another PC using the old CD drivers and see if it works. If it does, then it is a driver issue with the new PC. If it does not, you're back to reset . Hope this be of some help to you. Good luck and kind regards.
Jul 30, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 misaligned colours
Make sure the guides where the copy paper is loaded, are tight against both sides of the paper.
Jun 14, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon imageRUNNER C3200 Color Printer Logo
old marine
old marine
