Question about Optoma H30 Multimedia Projector
OPTOMA ts725 xga PROJECTOR a light & dark scrolling shadow lines
My projector has a white line and dark line that scrolls from bottom to top of the screenits not too noticable but you can tell.I called the tech at the company he said it could be a bad ground or rca. I tried both and it doesn't work. Its a 2 week old projector
PLEASE HELP ME!!!
  • digicjm Jan 23, 2009
    I have had two different Optoma projectors in different houses and they both had the same problem but only when connected to my computer via VGA cable.
  • 22 Answers
It sound like either the connection IS bad or the projector is bad. Try taking the projector back for another, it may be defective. Other wise it sound like the bulb is burning out but not likely after only 2 weeks.
Posted on Jan 09, 2009
When projecting the screen has a lot of white dots as though the lens needs cleaning ,the outside of the lens is clean
This is a dlp projector and has a bad DMD chip. Most models are very similar. Here is a video of a similar repair.
Feb 06, 2011 | Optoma EP727 XGA 2200 lumens DLP...
There is a line down right side of projected image, from top to bottom, different computers. Thanks Loren
I have a 2 inch white line down the middle of the screen from my Infocus DPL projector.
Can you help?
Paul.
Nov 29, 2010 | Optoma EP771 DLP Projector
I have an Optima Model EP719 Projector. Suddenly I am getting white vertical lines and can't find a solution for removing them.
I would try switching out the DVI cable first. It could be faulty. This would be the easiest and cheapest solution to check.
Jun 09, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Thick purple line scrolling up from bottom of screen continually
if it is a uniform pulsating line, then it is the main board or engine. if it is a fuzzy line it is the light tunnel
Apr 26, 2010 | InFocus IN72 Multimedia Projector
Optoma EP751, Just got a white boarder from top to bottom. Left.
try to reset.... or clean the board between av board and main board.
Oct 29, 2009 | Optoma EP751 EZPRO DIGITAL PROJECTOR...
VERTICAL WHITE LINES
I just read a post that said tap on the top and the line will go away. I tried it on mine and it worked! I had to tap it fairly hard. I just kept tapping harder and harder on the plastic in front of the buttons and voila! The vertical white line disappeared!
Oct 07, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Follow up on the Optima 719 with vertical white line
Hi Abouttime
Tapping can fix most electrical things for a very short while - unexplainable !
But I have been working as a authorised service provider on mos brands of Projectors for over three years now and in all of the times the white line was a faulty Mainboard.
This is just my opinion and I only answer and provide a free service to those who are in need.
Wheter you take my advice or not is entirely up to you.
Kind Regards
Marrie
May 23, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Vertical white line
My EP719 had the same problem. Did it once, briefly, soon after I bought it, then not again until recently, when the line came back more frequently and wider.
The projector was 20 days past warranty, and the company would not honor. So much for customer satisfaction and loyalty. Last piece of Optoma equipment I will ever buy!
Anyway, I found a web item on another model of Optoma projector with the same problem. The solution this guy tried was -- I kid you not -- rapping on the thing. With nothing to lose, I tried this on mine. Tapped lightly on the top and noticed a change in the width of the line. Hmmm ... it was sensitive to this.
Tapped harder. The line got narrower. Rapped pretty hard -- thump! -- and the line disappeared.
Since then I have been running the projector for hours, turning it on and off, letting it cool down, starting it up again. And the line seems to be gone. It may come back, of course, so this gonzo fix may not be permament. But if it works while I'm using it at a presentation, think of the amusement it will cause!
Oct 08, 2007 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma H30 Multimedia Projector Logo
391 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
