Question about Dyson DC15 Animal Bagless Upright Cyclonic Vacuum
Dyson D15 Animal is clogged, both in hose and in bottom
My Dyson D15 animal has a clog in the hose and also in the upright only part. How do I unclog?
  • Anonymous Mar 14, 2014
    hose is clogged
  • 3 Answers
Take pipe off and push a bamboo or somthing simular down hose
Posted on Apr 03, 2009
Problems with Dyson DC14 Animal Bagless Vacuum very little suction coming from the hose. cleaned filter and suction has not improved. Please help. Thanks
Two possible solutions come to mind. First off, there is a clog in your hose. If you have another vacuum, try using the hose on that one to **** it out.
If that doesn't work, you may need to have the clutch replaced. Check your warranty. The clog wont be covered, but the clutch will be,
Oct 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Loss of suction with hoss & wand with my Dyson Animal bagless - will only work as an upright.
It sounds like you have a clog through the hose. Take the entire hose off of the unit and stick a broomstick through, if it comes out the other end without anything coming with it. The clog is in the sweep below the unit. If your mechanically inclined you should not have any issues, if you do have a problem, take it to your local vacuum shop
Jun 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson Animal, lost suction and bypass valve seems to be loose
Dear terrygivens, 2-17-2009 4:12am EST (USA)
Most suction problems are caused by a clog from picking up something you probably didn't see or if you have pets an accumulation of pet hairs!
To clear it out take a metal coat hanger and unbend it til it's straight, then bend the end and tape it so when you push it through to unclog your vac it doesn't rip the hose.
Push the coat hanger in from the bottom brush area through the opening where the suction is. Also push it in and out anywhere else you can......You'll probably find something clogged....keep working it til it loosens and intermittently turn on the suction.
If you have a second vac with a hose, use that hose for suction on the clogged vac!
This should do it!
jack
Feb 15, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction when hose is removed from base
This should do it!
jack
Feb 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Does not have the same suction as when we first purchase the vaccuum. it is only 2 years old. We cleand the round filter at the bottom of canister. Any suggestions?
Sounds like you have a clog in the hose or from brush to the hose. To clrar turn vacume over and remove bottom cover to unclog where it meats the hose. I would use a coat hanger to unclog the hose.
Dec 16, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson Animal hose collapses when using attachment hose
You have a clog in either your hose or your wand. You need to take off the wand and hose and inspect them.
Nov 15, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson animal clogged,
if your bin opens from the bottom, you need that open to open the clip on the frount of the bin. i only discovered this by accident when i was emptying mine -i knocked it on the sde of my wheelie bin and it dropped off :-) hope this helps.
Oct 15, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Vacuum
you just need to blow those holes out with a air compressor or similiar device and the filter can be washed in water and dried for 24 hours every once in a while, this is just how the vacuum works, nothing is perfect
Mar 02, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson noise.
Check all ports for a clog, there are removable covers you can take off, also check the hose for a clog. Make sure all filters are clean. Worse case is a problem with the motor.
Jan 30, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC15 Animal Bagless Upright Cyclonic Vacuum Logo
762 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
