Question about Gateway M305CRV LCD VIDEO CABLE DDOA5LLC004 CD-ROM Drive
I am attempting to help repair a friends notebook pc. A few days ago she turned it off and the next morning when she tried to restart it the only screen displayed states that one of the main OS files is either missing or corrupt and to load the OS CD and press R to repair. We've tried this repeatedly, and each time the only thing that happens, is immediately after it restarts, it displays that same screen again. Now, I've put the OS disc in again and pressed F8, then pressed R for repair, but I am now stuck on the Recovery Console screen, asking me which Windows installation I would like to log parenthesis it states to cancel, press ENTER. So I pressed 1, to select "1: C:\WINDOWS" but nothing happened after simply pressing 1, so then I pressed enter after pressing 1 and then the following is displayed, "C:\WINDOWS>" without a blinking cursor behind it and I can hear that the disc I put in is NOT running. Can you please tell me the next few steps that I need to do in order to finish the OS repair?
    Brigadier General:
  • 5,158 Answers
First are you using the recovery cd(s) or a copy of xp.... if a copy ... skip by the recovery console and keep going as tho you are installing a new copy of xp... when you get to the point where it shows your drive... you will see the option to repair... now is the time to repair it....
Posted on Jan 08, 2009
2004 SRX - Sputtering, Stalling and Start issues
Have them check the camshaft/crankshaft sensor.. please indicate if my solutions are helpful thankyou
Apr 28, 2013 | 2004 Cadillac SRX
Water spilled on the table under the macbook. now it doesn't work. I see people wating a few days and it restarted. how nmany days should i wait? help!!!
Jay, Try placing your MacBook on a bed of un-cooked rice for several days that should pull any moisture out of your lap-top. DO NOT ATTEMPT TO TURN IT ON. If you already have it may too late.
May 06, 2012 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
How do i log in to my notebook as i have no password
That's nothing serious. I have come across such issue a few days ago, and I tried to reset Windows password in safe mode but failed.Thanks to my friend David who introduced me to use Windows Password Reset , I solved my trouble in a few miniutes.Besides,he also taught me some methods esle as use reset disk, accessible administrator account ect.
In these methods always one could help you.
Mar 06, 2012 | Sony VAIO PCG-K27 Notebook
My 47" Magnavox turned off, and would not come back on. A few hours later I tried it and it come on for about 3 minutes then went off and woudl not restart for a whole day. The next morning out of habit I...
The power supply board is dead,that the board,where the power a/c cord plug into it.Tries websites like, to buy a refurbish power supply board for the replacement.
Aug 12, 2010 | Philips Magnavox 42MF521D/37 Television
Dell laptop won't restart. No lights coming on. No power when hooked up to AC outlet with battery in it. What do I do? It did the same thing a few days ago,then I removed the battery,pluged it in and it...
if no sing of power when you plug in i would check AC adapter if is there voltage on it,
adapter plug could be interrupt conection (if yes you should change it)
- try to run it without battery
if it not battery or adapter problem i would go to restart BIOS setting to default, (when u finnally run computer) press F2 or esc when u turning on computer it will turn u to bios.
Hope it help
Mar 02, 2010 | Computers & Internet
96 aurora P0603 and P0300 codes
Sounds like you are having a PCM problem. The keep alive memory is internally located in the PCM. With all the other problems you are having, this is the most likely cause.
May 29, 2009 | 1996 Oldsmobile Aurora
ACER Aspire 5100 powers down at will
When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
Apr 15, 2009 | Acer Aspire 5100 Notebook
IBM R40 - 2897...not resonding
disconnect any power remove battery .remove mem and check the mem slots for dust and debris replace mem.remove hd check connections(hd pins)check connecter for dust.refit ;make sure properly housed.reboot,enter bios.reset to settings and exit.pc should now restart.any indications of fault maybe mentioned at startup if not window should boot
Mar 04, 2008 | IBM ThinkPad R40 2897 Notebook
Acer Aspire 4520 display off suddenly without warning
please clarify this sequence of events: "on AC power,it seems to be working fine. But the problem occurs when I try restart it on the next morning"... was it restarted next morning on AC power or battery...which one?
Aug 26, 2007 | Acer Aspire 5100-5033 Notebook
Computers & Internet Logo
95 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
