Question about Tomtom XL 330 Car GPS Receiver
My battery will not charge
Where on the device is the battery located?
  • 78 Answers
The TomTom is designed so the battery is not removable. TomTom recommend charging the battery for a minimum of 2 hours if you run into charging troubles, then attempting to reset. If this does not work, a call to customer service is recommended. They will then assess the situation, and if the product is defective, it will be covered under warranty.
Posted on Feb 03, 2009
Acer aspire 5935g battery problem
Many users do not use their notebook/notebook batteries correctly. The battery in a laptop/notebook/netbook is a rechargeable battery, like the battery in a Cellphone, a Digital Camera an eReader or an MP3/MP4/MP5 Player. This type of battery needs to both charge and discharge, if it is to perform to its maximum capacity and have a full, long life.
You would never dream of using a Cellphone, Digital Camera, an eReader or an MP3/MP4/MP5 Player only with the devices permanently connected to the mains electricity, because they are all devices that are designed to be used while the user is moving around whether indoors or outdoors, powered by their rechargeable batteries. the batteries of such devices are only recharged when the charge in their cells is depleted and then only for as long as it takes to restore full charge to them.
As with the other devices mentioned, a laptop/notebook/netbook's battery is designed for mobile use and the user should charge it to 100% full and then stop charging it to then use the device on battery power alone, until the battery is low on power, when the recharging cycle can then be repeated.
A notebook/netbook has more flexibility than the other devices mentioned because, unlike the other devices, it can also be powered directly from the mains electricity, without the battery installed.
If your laptop/notebook/netbook is mainly used away from the home or office, it is fine to leave the battery permanently installed. If, however, it is mainly used indoors at home or at work and always or almost always on exactly the same desk or table, then it makes little sense to use it either on battery power alone or with the battery permanently installed.
Charge the battery up to full charge and then disconnect the battery from the device and keep it safely for when you next need to use the laptop/notebook/netbook on the move (if the battery is stored for long periods it may require additional recharging to both maintain the battery's condition and to keep it fully charged because low level power dissipation takes place in a disconnected battery). Then connect the device to the mains electricity without the battery and continue using it like that.
If the laptop/notebook/netbook is mainly used in a single permanent indoor location, then charging has to stop when the battery has reached 100% full charge and should only be resumed when the device gives a low battery charge warning.
It is also important not to let rechargeable batteries drain completely by ignoring the low battery charge warming and continuing to use the device until the battery runs out of charge and the device powers down suddenly. Sudden shutdowns like this are neither good for the battery nor the device and can shorten the lifespan of both.
Continuing to charge any rechargeable battery when it has already been fully charged damages and shortens the life of the battery. It can even damage the internal Power Management System of the device if done over a sustained period of time and/or for prolonged periods of time.
When your notebook only shows 75% as the maximum charging level, this is an indication that one or more (probably two) of the individual cells that make up the battery are fully depleted, damaged and probably no longer capable of storing a charge, for the reasons given above. You should stop charging this battery after it has reached 75%, otherwise more cells are likely to become damaged and so on until the entire battery is dead, unresponsive and useless.
Nov 20, 2011 | Acer Aspire One PC Notebook
Will not turn on, and will not charge, totally dead
Or if all you get is a green light when its plugged into an external charger, then you could have blown one of two Microchips on the charging circuit and to get it working again they will have to be replaced. If it has just become corrupt you can try resetting the tomtom
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for at least 15 to 20 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Exact location of reset hole is in the picture below
Aug 09, 2011 | Tomtom GO 300 GPS Receiver
Charging port on X4T is disconnected, where can I get it repaired?
you can repair it or take it to radio shack
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Jan 26, 2011 | Nextar X4-T Car GPS Receiver
Dude, gps is dead again
Jan 26, 2011 | Tomtom ONE GPS Receiver
Gps device nothing operating
Jan 24, 2011 | Garmin StreetPilot C330 GPS Receiver
Vauxhall vectera 55 plate cdti 1.9 6 speed not starting engine turning centeral locking working battery strong electrical problem ????
Jan 21, 2011 | GPS
My tomtom doesn't hold a charge and it has touble finding a location.
First thing to check is are they actually being charged ALL the time you have them on charge. A couple of Ones which I've repaired myself had problems with the soldered joints for the connector on the printed circuit board. When the plug was wiggled about it made an intermittent connection and wasn't charging all the time.
Connect your charger and try wiggling the plug gently.
also your contacts may require cleaning this can be ddone by spraying "Switch Cleaning Lubricant" onto the contacts on the base of the unit.
Definitely make sure its actually charging, usually this can be done through the menus to see satellites and the battery life indicator. It will show if its charging or not...Electronic cleaner or even rubbing alcohol on a q-tip can work on the terminals. Making sure the charger is unplugged and the device battery is drained before cleaning should be a priority...
How old is the device. Despite what Garmin and Tomtom tell you Lithium Ion while being a good technology has its limitations, and the main limitation is its overall life span in combination with how fast it goes from what seems to be a good battery to something that barely holds a charge for a few minutes...
Its a standard lithium ion battery inside. It can be replaced relatively inexpensively. However getting too it can be tricky and I'd suggest reading up on battery replacement before attempting. Also for future reference keeping a lithium ion battery fully charged all the time will keep it lasting longer unlike older batteries that would develop a "memory" and benefit from being drained completely from time to time... the trouble finding location could possibly be attributed to the amount of power it gets from the batteries.
Jul 05, 2010 | GPS
Charging my MZ111
Plug it in to your computer using the supplied usb cable and it will charge it up like an Ipod.
Dec 29, 2007 | Sears TGE MP3 Player
Tomtom XL 330 Car GPS Receiver Logo
214 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
