Question about HP Compaq d530 SFF PC Desktop
I have a steady Red Light on Desktop but nothing on Monitor.
I booted couple of time but situation is same. Everything looks connected what you feel ?
  • 2 more comments
  • Anonymous Jan 29, 2009
    the red light flashes when you turn it on, and beeps continuasly, i don't know what the problem is
  • Peter VanderStoep
    Peter VanderStoep May 11, 2010
    Plese tell us more. Is this light normal? no drive lights? what about the display during boot? what messages flash by?
  • Andrew Podner May 11, 2010
    does the computer beep any certain number of times when you boot.
  • Sean Osborne
    Sean Osborne May 11, 2010
    Is there anything at all showing on your screen?
    Master:
  • 413 Answers
If your computer beeps when it boots it is telling you something follow the link below to find out what is wrong with your pc.
http://www.computerhope.com/beep.htm
Posted on Feb 10, 2009
Powers up, fans work, but nothing happens. Can not even get into the Bios. red light on between the power connection and the IDE connections?
I will assume that you have everything connected properly and are using the integrated video on the motherboard (not a separate video card installed in a slot). Usually the red light on the motherboard (mobo) is a power-on light, meaning that it is plugged in to a power socket.
First try to clear your CMOS settings:
Unplug the power cord and remove the CMOS battery for 15 minutes. If your mobo has a BIOS reset jumper, move it to the Clear position and back to normal. If you aren't sure what these things are, it will be in your manual that came with the mobo. Now re-connect everything and try again. Make sure that you are plugging the video cable into the proper socket and your monitor is working. If you can use a DVI cable on that board, try that connector. Make sure your monitor is working.
>Visually check for failed capacitors; caps that have ruptured are increasingly common and can stop booting.
>Your CPU may have failed; this is a typical situation then the chip fails. Everything works except there is no video on the monitor.
For more detailed testing and information, go HERE.
Oct 10, 2013 | QDI Group QDI Advance 6T Motherboard
HP xw4400 workstation wont boot/start if RAM are inserted.
If you are increasing the RAM from 1Gb to 2Gb then the RAM maybe incompatible. Try using a RAM module as the original make and speed.
Try installing one RAM module at a time to see if one of the RAM modules is faulty.
Removing the RAM will give a POST error code of no RAM or faulty RAM.
Feb 25, 2013 | HP xw4400 Workstation - 1 x Intel Core 2...
I cant boot up my acer aspire 8000 , only shows a " going to sleep " sign after i try to boot it up
Check if the CPU is connected to the monitor. also check if you find the power light is steady green on the tower. And their should be a green light at the back of the tower
Dec 13, 2009 | Acer Aspire 8000 (91.5A525.U33) PC Desktop
Won't boot. Series of Beeps plus red light
If nothing was displayed on the monitor during the beeps then change the RAM stick(s)
Thanks
Oct 29, 2009 | HP RT935UAABA - HP Compaq dc7800...
I am stuck in the boot up process with the option
Look at the HDD (Hard Disk Drive) LED light...
Is it a steady red? Put your ear to the computer case. Do you hear a repeating clicking sound?
You should be able to press [F10] to get out of the BIOS Setup. If not, it may be a loose hard drive cable (open up the PC) or a failing Hard drive (replace).
Oct 20, 2009 | Sony VAIO PCV-V100G (PCVV100GKIT1) PC...
Pc wont boot up, instead a red light flickers.
Flickering LED means power supply is overloaded with something. It might be inside of the supply, but sometimes it is something else. Try that:
1. Disconnect everything from the motherboard except power supply and power button;
2. Disconnect all power connectors from all drives;
2. Remove any cards from the motherboard so all you have is power supply and motherboard with CPU and RAM, nothing else. You can keep connected the monitor and keyboard;
3. Press Power button. Will motherboard turn on normally?
If no - check electrolytic capacitors especially around the CPU, if some of them are "popped" replace them.
If yes - connect drives and cards one per time to localize the problem.
Sep 14, 2009 | Compaq Evo D500 PC Desktop
Does the computer turn on all the way now or does it start to boot and then turn off?
Your Power Supply is no good, you are going to have to get it replaced. Once you get it replaced everything should be fine.
Jan 02, 2009 | Dell Dimension B110 PC Desktop
Computer powers on but does not boot - no videe output.
replace the ram if its bad you wont get any video..if that does not work it is the CPU..
Nov 17, 2008 | HP Pavilion 525c (DD210AR#ABA) PC Desktop
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Pop goes the weasel
I agree. The monitor probably blew a capacitor.
Time for a nice new LCD monitor.
Dec 14, 2007 | Computers & Internet
HP Compaq d530 SFF PC Desktop Logo
158 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
