Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
Backfire Tecumseh Generator
Approx 10 hours running time, 10 HP tecumseh horizontal mounted on a 5000 Watt Generator. Backfires every 3-5 seconds accompanied by a loud bang. Flames noticed shooting 3 inches out the muffler. Previous maintenance, new Carb, valves adjusted, fresh gas???
  • 32 Answers
To maybe convert your Flamethrower back to a generator, Make sure the fuel line is a good quality thick rubber material (like OEM )since it passes through the engine,HEAT is a issue, if it has been modified to steel, or it's thin rubber, it will overheat the fuel on its way to the carb and cause backfires after the engine warms up , ( vaporizing gas and pressure bypassing the jets flooding the engine) I use 1/4 inch Goodyear sold at Autozone , one of very few name brand quality parts you can get there. The other possible cause is carbon deposits built up on the leading edge of the valve not allowing the valve to close all the way, just clean the valve, it is caused by too lean or rich carb setting or clogged jets, if it is a newer style carb with a pink main jet then debris in this area will always cause backfire, check and make sure the old tiny O-ring on this jet is not still in the bottom of the shaft, people forget to pull them out all the time or give up trying to pull them out, I use a paper clip and bend the end 1/8 of a inch @ 90 degrees to fish hook it out of there, CLEAN THE SHAFT with carb cleaner and a Q-tip.... A Tecumseh engine will always backfire if the carb or airflow is not perfect and sealed tight !!!!!! it looks simple to rebuild the carb but you must take your time and look close, clean it very well, make sure the jet is SEATED properly and all tiny holes are clean, use guitar string not torch head cleaners as they will enlarge the holes and make your carb run rich.
Posted on Feb 05, 2009
I just had this problem on a tecumseh 12hp engine on a snowblower. The problem turned out to be a rubber hose that was off of the carberator. It was cracked and split. It was backfiring about every 5 - 10 seconds. All I did was snip the hose and put it back on and it ran fine. It was not the fuel line, I think it was a line for the primer. At any rate that would be something to check.
Posted on Dec 31, 2010
  • David willis Dec 17, 2012
    I HAVE A TECUMSEH 10 HP GENERATOR AN WHEN I CRANK IT IT RUNS FOR 2 TO 3 MIN AN BACK FIRES AN CUT OFF I CHANGETHE GAS LINE AN FILTER IT STILL DOES THE SAME THING . DO YOU HAVE A SOLUTION TO MY PROBLEM. NEED HELP WHAT CAN I DO TO KEEP THIS GENERATOR RUNNING AN STOP BACK FIREING
Have a 12 hp Tecumseh engine that bvackfires with ohv
Your problem could be one of several things.. A bad spark plug, bad gas, failure to lower the idle and let it run a few seconds prior to shutting it off, unadjusted valves, etc.
I'd start with the plug and some fresh gas, then go from there. Always idle the engine down for a few seconds before shutting it off. This allows all the gas in the combustion chamber to be burned up preventing backfire.
Jan 14, 2012 | Tecumseh Enduro Vertical Engine 16 HP 1in...
Need to know what oil to use in 10 HP 5000 tecumsah engine - goes on our generator and I lost the manual
It depends on what temperature range the generator will be operating in. Below is a chart from Tecumseh that shows different oils for different temperature ranges. It says on their website to use a high quality brand name oil so you don't have to get actual Tecumseh oil.25b21be.jpg
Feb 26, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman 5000 watt generator Tecumseh 10 hp engine. Surging r.p.m. Carburetor has been gone through 2 times, and still not correct. Any information will help!!!
it's running lean.....try resetting the choke partially when it begins to surge.....not completely closed, but enough to richen the fuel mixture (that's all a choke does btw..)
if that helps or clears the problem, your carb is outta whack.....cheaper to buy a new carb than keep taking back into the shop.
Jan 07, 2010 | Coleman Powermate Powermate 5000W...
Is there any way to quiet down my Tecumseh Craft. Gen?
longer exhaust pipe from motor and better muffler. Go with a larger pipe too to allow for better engine performance. You can get a tractor muffler from Tractor Supply that meets your needs.
Oct 07, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Hard to start and backfires from muffler when running
Sounds like the timing may be off or maybethe exhaust valve maybe hanging open.
Mar 15, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh HM80 on coleman generator. won"t stabilize, backfires. new plug, fresh gas 'carb cleaned. starts first time'new air filter. any suggestions?
check to see if it has a smeared or worn key way it is what times the fly wheel to the engine if not it is possible that it coul have problem with a valve or engine timming
Mar 01, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Switch missing on 10 hp Tecumseh engine that is installed on a
First I have never owned a Tecumseh Tiller. How that got attached to me I don't know. I do have a 10 Hp Tecumseh Engine that I wish to check out if it is good or not before I buy a switch. It has a Brown wire that goes to the low oil shut down sender. It also has a green wire and a black wire. All I need to know is which wires do I need to put together so I can check if the engine is firing or not.
Feb 19, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
4,054 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
