Question about Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HCJ552w CRT rear projection with a broken ASSY CRT-B.
I have samsung HCJ552w CRT rear projection TV with a broken ASSY CRT-B. Is it worth fixing?
  • 133 Answers
Not worth it, when you replace one, your saposed to replace all 3, otherwise the picture looks funny, probabily a 600 dollar repair
Posted on Jan 09, 2009
I have a samsung hcj552w rear projection tv. Every time the power goes out the tv will not turn back on unless I unplug it for a week or 2. When the power goes out then it comes back on just the red...
Replace the STK ICs,STK392-020 they are big black ICs and will have Part Number on them.Also CK the Low Ohm resistors in front of ICs. Mats Electronics has ICs 1-800-628-1118
Oct 29, 2010 | Samsung HCJ552W 55" Rear Projection...
Tv wont turn on
usually indicates that the lamp is burned out,the ballast is dead or the power supply board has failed. you can do the lamp yourself but the others would need a technician. call 1-800-samsung for nearest service center.
Nov 17, 2009 | Samsung HCJ552W 55" Rear Projection...
TV has faded and is grainy.
Rear project televisions use high voltage capacitors that lose their capacitance with age. Most likely there is a low voltage problem. You cannot repair this yourself because of the DANGEROUS high voltages inside such a set. Call a service technician.
Oct 10, 2009 | Samsung HCJ552W 55" Rear Projection...
No digital reception with HD ready TV.
Someone did not explain to you what HDTV "Ready" means. It means you do not have a ATSC tuner in it to except over the air digital signal. The only way you will get digital reception is either from a HD Cable box with RGB outputs that plug into your RGB inputs, or being on Satellite connecting the same way. Seven years ago manufacturers never made it easy to understand and Salesmen only made it worse. So in short the term HDTV Ready meant it can, with a BOX.
Jun 13, 2009 | Samsung HCJ552W 55" Rear Projection...
HCJ552W 55' samsung rear project....won't turn on
dear friend you have a power supply problem, get one of those cheap meters and open the set, look for a blown fuse, if they are ok wich i doubt, you have to call the repairman.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Samsung HCJ552W 55" Rear Projection...
Samsung rear projection tv
It probably is see if you can align the convergence manually or auto if available, you can order just the convergence ic's or the convergence amp board, whichever you prefer. check pricing and availability. also check Blue crt for faded picture, usually dirty crt fluid, makes picture dark and discoloured. If it is you may need to replace the blue crt also. this gets a little expensive, again check pricing hope this gets you started RFT
Jan 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Samsung HCJ552W Picture "expanded"
Change the aspect ration in the customer menu and take it out of zoom...
Nov 05, 2007 | Samsung HCJ552W 55" Rear Projection...
Samsung HCJ552W convergence out before warmup
If set has a few years on it, the convergence may be going out.
Jul 16, 2007 | Samsung HCJ552W 55" Rear Projection...
MITSUBISHI rear projection
What is the TV you have two differant brands /makes?and I dont know what that symbal by the b is?
Aug 09, 2006 | Samsung HCJ552W 55" Rear Projection...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
75 people viewed this question
Jerry Greenberg
Jerry Greenberg
