Canon 5870 PAPER JAMS
I am having paper jams where the paper 1st comes out of the paper tray
I have tried changing paper, Switching drawers, Cleaning the rollers with just a moist cloth & am still having touble. CAN YOU HELP???
  • gduncan Jan 09, 2009
    THERE IS ACTUALLY A SENSOR IN THERE THAT CAME LOOSE I FOUND THIS AND REPAIRED IT LAST NIGHT
    President:
  • Office Equip... Master
  • 990 Answers
Hello sir; You have to clean roller with rubber rejuvenator( get it from stationery store) then willtake care your problem,good luck.
Posted on Jan 08, 2009
Paper jams every sheet. Checked the paper weight, made sure it was faned edges and not rolled. Catches on the left side as it rools in from the drawer. What can I do to fix it. I have used it many...
Marie, there is something stuck between the paper tray and the transport section of the copier. Probably a small piece of paper. try to push a piece of paper up from the tray to the rest of the machine to push this obstructing paper out of the paper path. Also try using the handfeed section on the right hand side of the machine by folding down the tray and putting paper in it. You may have to choose this "manual" feed tray on the operation panel. Good luck !
Feb 20, 2011 | Canon imageCLASS D860 All-In-One Laser...
Paper jams and message comes up that the paper tray is empty even tho there is paper in it why is this happening ?
You might try checking to make sure there that the paper is set in the tray correctly. Here are some other things to check:
http://cincinnatiprinterrepair.com/paper-jams
Aug 11, 2010 | Canon PIXMA MP470 All-in-One Printer
Copier keeps telling us there is paper jam, we have looked where screen shows jam and find nothing. We have taken out the paper tray, still don't find even a tiny scrap of paper anywhere.
There are several possibilities. After you inspect for the Jam and close the drawer, does the copier come to ready? Have you checked the behind the doors on the right side. If the copier comes to ready and you press the start button does the copier jam right away. If so check the dial on the paper drawer and be sure its set to the right size paper. If its not the copier will jam, right away. It is important with a Canon to check all areas and open both the paper drawer and the right side doors when checking for jam, if the right sequence is not followed in checking for jams the jam may not clear. If still Jammed you might take some canned air open the right side door and blow out the paper feed area, a sensor may be blocked or dusty. If all else fails turn the machine off and un-plug it from the wall, let it set a few minutes and plug it in and try it again.
May 20, 2010 | Canon imageRUNNER 2000 Copier
I keep getting paper jam on my copier, tried cleaning the tray and feeder compartment but still the jams and squeezing of paper. what should i do pls
Try it from another paper tray and see it if still jams. IF it goes through, your first tray needs a roller cleaning or new rollers. Is it jamming out of the cassette or up into the fuser?
Feb 11, 2010 | Sharp AR-275 Copier
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Paper jam
It jams due to the rollers. Please change the rollers and it should be good. also pay attention to the way the paper is being seated in the drawer.
Jun 29, 2009 | Samsung CLX 3160fn All-In-One Printer
Our PC1061 has been wonderfully reliable. Very recently we have 2 copier problems: One problem is there is frequent paper jamming coming out of the paper tray just below the toner cartridge and secondly,...
Hi:
Slide the drawer out completly and look into the cavity on the right side. You should see two D rollers that pick up the paper form the paper cassette. Clean these with alcohol. They an get dirty with time and cause paper jams.
Good Luck
Andrew
Jun 27, 2009 | Canon PC1061 Copier
''place paper in drawer''
Sounds like a paper sensor ; A little black arm that senses paper tray is full, when the tray lifts into position. You might pull the tray and with a flashlight look for any broken parts. I have seen these break when paper jams are removed. This is a Toshiba 2860 correct?
Nov 18, 2008 | Office Equipment & Supplies
My printer jams frequently
More info is needed where does it jam ie. going to print from paper tray or coming out of the fuser in back before it comes out on top?
Feb 26, 2008 | Lexmark E330 Laser Printer
Paper Jams
Try changing out the toner cartridge if cleaning rollers didn't work.
Jan 07, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
90 people viewed this question
jasbo
jasbo
