Question about Yamaha RX-V1800
Yamaha Rx-v1700 receiver HDMI Video stopped working
I have a Yamaha Rx-v1700 receiver that has worked great for a year and a half.  I was messing with some cabling, and suddenly I have no HDMI video out. I tried different cables, and just about everything else.
Is there a setting that may be wrong, or is there a way to reset the box to factory settings?
I did the factory reset as suggested in the manual, but it does not change advanced settings.
SA 8300 HD, Yamaha RX-v1700, Hitachi HDP-J52
  • Scott Frye
    Scott Frye May 11, 2010
    Hi...
    Have you tried the HDMI cable direct to your video monitor?
quang123
  • 107 Answers
SOURCE: problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Posted on Dec 01, 2008
  • 120 Answers
SOURCE: yamaha rx-v1900 receiver suddenly cut
do you have the ventilation holes covered so air cant get in to let heat out? it sounds like a thermal related problem.
Posted on Jan 06, 2009
SOURCE: Need Scientific Atlanta code for Yamaha Rx-V663 remote
043, 011, 003, 041,042,045, and 046
Posted on Jan 24, 2009
SOURCE: zune and yamaha RX-V663 Receiver
Buy the Zune A/V kit and hook it up to a non used rca port on the back. Look for the older ones for the 30 gb units, they are much cheaper than the new ones and it takes 10 seconds to modify them to use on the newer units. The A/V kit has 3 rca plugs, one for sound and 2 for video. If you pick a source that can play video and sound on your receiver, then the screen on the zune will display on your television. The A/V kit has a remote with it also so you can control the zune from the room. I have not tried it, but since the Zune remote is IR then if you have a good all in one remote, such as a harmony, you may be able to program the codes from the Zune remote into it and even be able to control your stereo and Zune from one remote. Hope this helps.
Posted on Feb 28, 2009
  • 7 Answers
SOURCE: Compatibility issue: Sony BDPS350 Blue-ray & Yamaha RX-V1700?
HDMI compatibility issues continue to plague the industry and this more than likely is the problem. There are a couple of ways around this.Some people insist on "hot rodding" the dvd and tv by hooking up directly to each other avoiding the receiver all togeether (I do this).But you lose functionality and it makes things more complicated for other family members. Your best bet is to use RGB and Digital audio cables.You won't notice any quality loss and there is a possibility it will look better.
Posted on Jul 07, 2009
Power failure with yamaha RXV1600 areceiver
Google yamaha rx-v1700 power problem and you will find that a
capacitor # C4 is failing throughout the RX-V line of receivers. It's
an easy replacement fix but on some earlier models it may be
labelled C6 - the fix post has pics of it and specs - readily available.
Capacitor is a 0.022UF 630v.
Apr 07, 2014 | Yamaha RX-V1600 Receiver
Yamaha rx-v663 no video from hdmi out
Unfortunately the most common cause of this is the HDMI transmit IC on the digital board. Sometimes replacing this IC will work, but most of the time you will need to replace the digital board - this is expensive. If you don't have a warranty that is still valid, it may cost more than a new receiver.
Dec 23, 2012 | Yamaha Audio Players & Recorders
Yamaha amp rx-v1700 is locked. no power. micro not turning it on.
unit will not turn on fuse is ok can anyone shed some light on this problem please
Aug 04, 2009 | Yamaha RX-V1700 Receiver
Problems connecting Yamaha & BluRay player on Portable Computer.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
Jan 12, 2009 | Yamaha RX-V661 Receiver
Dec 29, 2008 | Yamaha RX-V1700 Receiver
Audio but no video from Sony Blu-Ray w/ HDMI hookup to RX-V663
Okay...my first contribution to any forum but I have the same problem (Yamaha RX-V663 and Samsung Blu Ray) and found the solution. The problem is you probably have your HDMI cables from your DVD player and reciever connected to a DVI input on your TV. The DVI may have problems communicating--not HDCP compliant. My system was working great then I hit a button on my remote...just playing around. I think it was the pure audio and I turned off the receiver. After that, the audio worked but there was no video. After many frustrating hours, the fix was to unplug the HDMI and DVI cable then turn the power off, cycle the power again, and plug the HDMI and DVI cables back in (the DVI was the last cable plugged in, not sure if that matters). By unplugging everthing you've reset the communication between the HDMI components and the DVI TV.
See page 18 of the yamaha owners manual, second to last note on bottom right of the page. It says there may be a problem...
I also noticed that the yamaha reciever was sending 1080p (my older tv is 1080I) and that is why the video wouldn't display on the TV. You can see this in the video signal info screen, unfortunately there is no setting to switch it back, just recycle the cables and power and it should reset.
Uncredibly frustrating but I got my picture back!
Jason
Dec 01, 2008 | Yamaha RX-V663 Receiver
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Jan 18, 2008 | Yamaha RX-V2700 Receiver
Yamaha RX-V1800 Logo
351 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
