Question about HP Compaq nx6110 PC Laptop
Need repairs My laptop screen is cracked. How much would it cost to fix- would I be better off getting a new one? Where could I go to get it repaired?
    Problem Solver:
  • 21 Answers
THE SCREENS IN LAPTOPS ARE ACTUALLY SEVERAL LAYERS, THEY USUALLY ARENT REPAIRED. YOU CAN HAVE THEM RESURFACED IF THEY ARE SCRATCHED OR NICKED BUT WHEN YOU HAVE A CRACK IT IS CHEAPER TO EITHER BUY A PIECE OF GLASS AND REPLACE IT YOURSELF, THE NX6OOO'S I THINK HAVE A 15" SCREEN IN THEM, MIGHT BE A 15.4" EITHER WAY YOU CAN USUALLY FIND EITHER A USED PIECE OF NEW PIECE ON EBAY PRETTY CHEAP, ITS NOT THAT HARD TO CHANGE THE GLASS SO LONG AS YOU KEEP ALL THE SCREWS YOU TOOK OUT :O) I WORK FOR A COMPUTER PARTS DISTRIBUTOR AND KNOW FIRST HAND HOW TO TAKE THEM APART AND PUT THEM BACK TOGETHER. I WOULD SAVE YOURSELF SOME MONEY DOING IT YOURSELF AND BUYING JUST THE PANEL OF GLASS. ONCE YOU TAKE THE DISPLAY APART THERE ARE NUMBERS ON THE BACK OF THE PANEL ITSELF THAT WILL GIVE YOU THE EXACT "OEM NUMBER" TO ORDER BY. I CAN HELP YOU WITH THIS IF NEED BE AS WELL YOU CAN EMAIL ME AT KUSTUMSPEED@AOL.COM
Posted on Jan 10, 2009
  • 44 Answers
See the link below. It will be cheaper than buying a new laptop.
http://base.google.com/base/a/309518/D14770463562198189822
Posted on Jan 08, 2009
Cracked screen please let me know if its cheaper to fix or just buy a new one. Fix or not?
This depends upon an number of things. I'm assuming the unit is at least 32-inches diagnoal.
Repair will probably cost upwards of $200 depending upon the size of the screen.
How old is the unit? If it's older than 3 years, replacing it would give you a better overal performing unit.
What size screen is it? The size of glass replacement could be costly.
Is it just the screen that is cracked or is there something else wrong with it. If it's older than 3 years, a new one will be better. New units are much more reasonably priced now.
Also, before you decide I would make a few calls to local repair shops to ask the estimated cost of replace and repair and how long the repair will take (parts could be a problem).
Dec 11, 2010 | Televison & Video
Were in India (gurgaon)can i get my toshiba A Satellite Series screen repaired and what is the cost? The screen has cracked accidentally !
just fyi before you make any decision on laptop screen repairs.. we have found that the screen costs just as much a new laptop (that is if you have a cracked or broken screen). better off buying a new laptop.
this is only valid if the laptop is not under warranty. If it is under warranty best to check the Toshiba website for accredited repairers in your region/location.
good luck hope this helps'
Oct 08, 2010 | Toshiba Computers & Internet
Ihave cracked the screen on my compaq lap top where can I get it repaired?
Hi
Unfortunatley,the repair cost is going to be higher than a replacement.
You can do a search for compaq laptop parts and look for displays for your model,and also check Ebay.
But if your's is an older model it may be better to replace it and start off with a new warranty and better performance.
Let me know if you have any questions,and would you rate my post please?
Bob
Aug 19, 2010 | Compaq Computers & Internet
Can Dell Inspiron 2200 screen be replaced/repaired? How costly?
If the screen is cracked, that can range from $200 and up. If the screen is not cracked and the image is garbled or scramble, then the Price of repair would be at least as much. Laptops are expensive to repair. Bear in mind, They are mass produced, not mass repaired. In my opinion, your money might be better invested in a newer machine.
Nov 13, 2009 | Dell Inspiron 2200 Notebook
ACER ASPIRE 3680 LOOKS LIKE INK IS BLEEDING INK INSIDE OF IT..
It indeed is a fairly easy repair in case of your Acer. However you will need a replacement screen which would cost a lot if you order it new. You might be better off searching ebay for a broken "donor" laptop (make sure it's exactly the same model, as even similar models with same screen dimensions might have different connectors or inverters - I learned the hard way ;)
Good luck,
Raf
Nov 08, 2009 | Acer Aspire 3680 Laptop
The back cover of my Acer Extensa 5220 laptop is cracked
It would cost about $100-200 for parts.
That doesn't include the repair time. For me it would take about 10-15 minutes.
For a novice about 1-2 hours.
That's the jest of it.
New laptops $200-400 for decent rigs.
Jun 19, 2009 | Acer Extensa 503T Notebook
Flat screen tv feel off wall cracked can it be fixed
yes it can be fixed by a repair center.but if the internal circuit board is craked or broken it will cost very heavy to get it repaired.if the screen and outer frame cracked the cost will be ok---ok. get it fixed.
Mar 14, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
My labtop screen is cracked on my acer is it possible for me to send it in to acer an have it repaired. if so where do i send it?
Your screen can be fixed by Acer but you'll have to pay for the service.Cracked screens are not covered under the typical manufacturer warranty.You'll have to call Acer to get a quote on how much it will cost to have that fixed.Call them on 800-816-2237.It is sometimes better to get a new laptop if it will cost too much to fix it.
Aug 21, 2008 | Computers & Internet
Have A Cracked Screen
Ask the manufacturer what their cost of repair is - unlike with cars, the manufacturer usually has the best price. If it is better than the cost of getting a new one - go for it.
-Tha Mp3 Doctor
Feb 11, 2008 | SanDisk Sansa e260 MP3 Player
HP Compaq nx6110 PC Laptop Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
