Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Dishwasher not working
I have a two drawer diswasher where the bottom draw has stopped working. It starts a cycle, then after approx. 1 minute the screen goes red and it beeps. When I open the drawer there is water in the bottom and it will not do a full cycle. Each time I need to turn the power button off and try again with the same problem. The top drawer is not washing the dishes properly. Please help
  • 4 more comments
  • Toni Stevens Jun 04, 2007
    Tried disconnecting the power and waiting ... then starting it again.
    Drawer starts filling then screen goes red with the error U3 and has to be turned off.
    Help.
  • Anonymous Dec 02, 2007
    Same problem with the top drawer. Made sure filter was clean and motor could rotate. Haven't got much further.
    Greg
    Top drawer does not complete cycle. Would fill in the rinse mode but not pump out. Will now not commence. Tried cleaning the filter and checked that motor was clear. No damage to wiring or hoses.
  • Anonymous Jan 04, 2008
    MY DISHWASHER JUST BEEPS AND THE WATER WILL NOT DRAIN. I CAN NOT USE THE DISWASHER AT ALL. I HAVE TRIED TURNING OFF THE POWER AND THE PROBLEM CONTINUES. PLEASE CALL ME WITH THE NAME OF A REPAIR SERVICE IN THE KANSAS CITY KANSAS AREA AT 913-334-7426
  • Anonymous Aug 04, 2008
    the drawer has water in it after every cycle, that won't drain.  Dishes have a soapy film.
  • Anonymous Mar 26, 2014
    LIKE J WROTE ,AFTER EVERY WASHING PROGRAM IS RUNNING ONLY 3 MINUTES AND ON DISPLAY IS WRITE END/ SO TO BE CLEAR- THE APPLIANCE AFTER START ANY PROGRAM, STARTS NORMALLY, IS TAKING WATER, AND AFTER 2 MIN START TO DRAIN ALL WATER FROM INSIDE, EVERYTHING INSIDE IN APPLIANCE IS DRY NOT WASHED SO WATER LIKE J SAW ONLY IS ON BOTTOM OF APPLIANCE AND AFTER 2MIN START TO DRAIN FROM APPLIANCE AND THE WASHING PROGRAM ENDS SHOWING ON DISPLAY
Have got the problem sorted. Water got into the control panel which changed the setting for the water pressure. Have now re set the setting and our dish washer is back up and running as normal. If anyone else has the same problem... I will not down the way to amend the setting.
I suggest that when unloading your dish drawer, that you wipe the control panel dry after every use to stop water getting into it.
Hope this helps others.
Fishgirl
Posted on Jan 07, 2008
I had this unit given to me by a builder and they cut the power cord upon removal.Is there a certain plug (FP) I should use or can I just go to Home Depot and pick one up with the proper rating?
Posted on Jan 06, 2008
  • 883 Answers
Disconnet power to unit....circuit breaker...wait 30 minutes....try again
Posted on Jun 02, 2007
    Problem Solver:
  • 5 Answers
Hi there Fishgirl, Is your machine intergated with your kitchen or does it have a factory finish. If it is intergrated when the product stops open the drawer and tell me which wash cycle is lit. If it is a factory finish product, ie Stainless steel, does any fault code come up on the display screen on the front of the drawer. Kind Regards Carmen
Posted on Aug 09, 2007
3 problems: 1. lower drawer is hard to close; seems to be sticking on something. 2. lower drawer retains water (2 inches) after completing a cycle. 3. F1 fault code on both drawers with alert...
ok where to start, first thing the bottom draw is hard to close because they use 2 little motors on either side to pull a lid with a seal on it down on top of each draw when u start it to keep the water in, if its hard to close the motors are damaged and arnt lifting the lid back up when the cycle finishes making it hard to open and shut, now the F1 fault means the filter circuit board in the base of the machine has been activated basically a flood sensor (and controls minor components ie lid actuators), the unit should beep and flash and go spaztic and you should hear the drain pump come on continuously til u turn it off at the wall thats its way of trying to stop a leak by removing any water it can but will not actually remove the water from the base where the switch is, you will probably find it will work now as the water will have dried and stopped triggering the switch but wont stay like that for long, that machine has major issues its leaking bad from somewhere and id say it leaked onto the lid motors and fried em, the parts you will most probably have to replace is the filter board in the base, both bottom draw lid actuators (small motors), probably the bottom draw lid if you damaged the seal pulling the draw in and out and whatever is leaking and if any other componets where damaged by water, so if its outta warranty id go buy a new 1 with 5 year extended warranty
Oct 26, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
Jan 29, 2008 | Asko 24 in. D3120 Dishwasher
Drawer won't open and get beep code 2 short 1 long
The drawer door seal is locked in. This could be either because the controller has lost power or the seal actuator motor is faulty.
You will have to force open the drawer before you can do anything. (Turn off the mains power when you work on the dishwasher)
Let me know if you can handle electric/ mechanical repairs so that I can guide you further. Otherwise you should call a technician. If you are getting beeps then most likely the door seal system is the problem.
Are you able to use the top drawer?
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Son put normal dish washing liquid in top draw!
ok, the machine flooded and the water has leaked into the bottom of the machine, 1st turn off the machine at the power point. 2nd- open the top drawer and remove the suds from it. 3rd. open the bottom drawer and look under it to the bottom of the cabinet . that is where the water will be. use a torch if you have to. now you need to dry the water up. you can do this with a hair dryer or a fan heater. the reason the machine is flashing F1 is because the water has triggered the flood switch and you need to dry up that water. please reply 4 more help.once dryed F1 will disappear. please make sure all the suds are removed from the top drawer. good luck
May 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Rinse cycle on top drawer keeps turning on
You have a leak due to the Lid seal leak.
1- Unplug the power, then pull out top draw half way and
2-Touch the bottom top housing ( not bottom top draw) you will feel it wet. Try to dry it by stick in a towel.
3- Repeat the same for the bottom drawer.
After drying out, wait for at least 1 day so the sensor can be dried out then plug in the Power, you will be fine.
4- Contact me for the next step.
Jul 01, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F 1 Error, blinking, beeping and will not stop even when turned off, so we had to turn the circuit breaker off to stop the noise.
You have a leak.
Either from the top lid seal or bottom lid seal. A s time goes by the water level activates the sensor causing the beep. It won't do anything until you fix the leak.
May 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
Jul 19, 2017 | Maytag 24 in. MDB5600A Jetclean II...
Top Draw flashing lights and playing music!?..
this sounds exactly like the problem we had the tech cam out removed the draw and found hte fuse on the heater element was blown -Because the dishwasher was under warrenty he replaced the heater the computer and gave us a new impella
********I'm guessing here but I think you can replace the fuseable resister in the heater element and all will be fine***
Oct 18, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Dd603 top drawer won't start
on the hinge slide there is a micro switch the draw needs to be removed to locate it.
Jan 26, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwasher will turn off
Mami, first see if you can put it through a test cycle by pressing the heated dry button six times and then press start. 88 will display. This will test all the funtions of the dishwasher. Let it do it's thing for approx. 20 minutes. Wash motor should run. If it doesn't call for warranty service so you don't void it. It's possible something got messed up during installation. Catriver..post back.
Jan 04, 2007 | Maytag 24 in. MDB8751AWS Stainless Steel...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
801 people viewed this question
Top Fisher and Paykel Dishwashers Experts
TomDicker
Level 1 Expert
Simon Flummox
Simon Flummox
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
