Question about Kenmore 15864/15862 Top Load Washer
Fills the hums loudly
First the washer filled and drained correctly but did not agitate or spin. I replaced the motor coupler (it was definetly broke) then put it all back together. Now it will fill, and when it is supposed to start agitating, it hums very loudly like something is froze up?
  • uksoccer107 Jan 08, 2009
    I looked inside the pump just to be sure, nothing there, Let me give you more info, It was just one day ago that the washer filled and drained properly, I tested it again this morning, Went ahead and replaced the coupler, then immediately after doing so, it will now fill but then hums loudly when it is supposed to agitate, and it will not drain either.....as if me replacing the coupler caused it....haha. You cant screw that up can ya? I aligned the holes and everything went fine, also, while i was replacing it, i did turn the motor freely, and whatever it is is on the other side of the coupler, the gear box/ transmission?
    no, it hums loudly like it does when it stops filling and goes into the agitate cycle
  • 242 Answers
Hello , Have you looked inside the pump where the hose comes from the tub , there could be an item clogging it , also try turning the pump where the shaft goes by hand , it should turn freely.
You can also try turning the gear case with the motor off where the coupler is attached , 1 direction will agitate and the other direction spins , you should be able to turn the gear case both ways and it will not turn easy.
if all of these check out the motor could be bad but it is highly unlikely.
let me know how it works and if you have any other questions.
Phil
Posted on Jan 08, 2009
  • Phil Brantley
    Phil Brantley Jan 08, 2009
    what happens when you set the timer to spin , does it spin?
  • Phil Brantley
    The only thing you can check now is the gear case [componet behind motor].
    take the motor back out and turn the coupler prong on the gear case about 10 full turns each way , if it stops and wont turn the gear case is locked and your motor can not turn it. tell me how this works.
    Phil
Replaced the clutch and motor coupler a month ago. Ran great. Washed tennis shoes. Came in to remove clothes, didn't spin. Wont agitate or spin, i could hear the motor running. Just replaced the motor...
Check for a failed capacitor under the control panel It is a start/run capacitor that the motor needs to start running. The motor will hum and if left will eventually burn out.
Aug 17, 2013 | Kenmore 23822 Top Load Washer
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Jan 13, 2011 | Kenmore Washing Machines
Washer was working made a clicking/humming sound now the aggitator doesent work and wont spin. Still fills and drains.
your motor coupler is broke,tip the washer back and look between the motor and trans that is where the coupler is located-mike
Feb 19, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Aug 13, 2009 | Kenmore Washing Machines
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Jan 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kitchenaid Washer Model #KAWS700JQ4
Washer has a motor coupler linking motor to transmission. If this motor coupler is broken or has rounded out where it engages the motor and/or transmission gear it will only fill and drain. You can view this coupler by leaning washer back against the wall & looking underneath with a flashlight. There may be a sound dampener panel on the bottom that you have to remove to see it. It is two pieces of white plastic with a rubber grommet in the middle.
Dec 15, 2008 | KitchenAid KAWS700L Top Load Washer
Ge wvsr1060a2ww washer does not spin or agitate
first look to see if this is a belt drive. If not look for a coupler(round black rubber piece with three holes, three plastic fingers from both sides going in it) from the motor to the gearcase. The motor sit between the pump and gearcase, it will pump out, but not spin.
Nov 08, 2008 | GE WVSR1060A Top Load Washer
Will not agitate,spin or drain
There's a coupler that normaly goes.just tip the machine over and loosen the motor.the coupler will be 3 legged and plastic.just replace and it should be ok.
Feb 22, 2007 | Whirlpool LSR5132PQ Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
151 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
