I have a tear in the driver side rear door speaker in my Acura MDX. 2001 Acura MDX, Bose System. Is there a repair shop in Phoenix that can change out the front paper piece, or do I have to bite the bullet and buy the dealer replacement part? John
    Scholar:
  • 67 Answers
Hi, i am in the uk so can't say if it is different localy to yourself, but you may save cash if you look to source "Legacy" (U.S.A. brand) replacement speakers . They have quite a low cost start point and sound really good if system matched with a amplifier from the same brand. You may even be able to source some adapters that will allow you to install bigger sizes - bigger IS better. Most only use a few wires so fitting is easy to do at home.
Posted on Jan 09, 2009
How to change rear main engine seal on acura mdx 2001
http://www.mdxers.org/forums/73-2001-2006-acura-mdx/47786-mdx-transmission-rear-main-seal-diy-tutorial.html
Jul 31, 2014 | 2001 Acura MDX
I NEED A FREE SCHEMATIC FOR 2001 ACURA MDX STEREO MODEL 39101-S3V-A131-M1
Hi there:
I suggest to check this on 2001 Acura MDX Car Stereo Radio Wiring Diagram...
Radio Constant 12V+ Wire: White or White/Blue
Radio Ignition Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: Yellow/White
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 29, 2012 | 2001 Acura MDX
Need to replace a front heat blower resistor on 2002 mdx, where is located???
moz-screenshot.pngHere's an excerpt from the 2002 Acura MDX 4WD 6cyl Repair guide for replacing what the reference manual calls the "control assembly" - its located under the console rear trim and may (or may not)
contain the blower resistor - my manual doesn't say - but this is the closest thing I could find for you. Every other blower resistor I've had to find was located close to the heater controls - and this
car seems to be no exception -- its heater controls are located in the console between the seats, rather than in the dash (as in Acura 2003-06 MDX models).
You may want to call your friendly Acura dealership ad speak to the parts department, to make sure where the blower resistor is located - or a visit to a dealership parts counter often (or
Advance Auto Parts is helpful too) ofen clarifies questions I have from Haynes manuals (the cheapest car repair guides).
All this assumes that you've correctly diagnosed your blower control problem -- as in "replace the blower resistor when the blower works only on the MAX/Highest setting."
-- begin excerpt from 2001-2 Acura 4wd 6cyl MDX Repair manual --
Control Assembly Removal & Installation
2001-02 Models
  1. Remove the console rear trim. Refer to the accompanying illustration.
    Fig. Exploded view of the console rear trim
  2. Remove the self-tapping screws and the rear heater-A/C control unit (A) from the console rear trim (B).
To install:
  1. Install the control unit in the reverse order of removal. After installation, operate the control unit controls to see whether it works properly.
  2. Run the self-diagnosis function to confirm that there are no problems in the system.
    Fig. Remove the self-tapping screws and the rear heater-A/C control unit (A) from the console rear trim (B)
  3. --- end excerpt from 2001-2 Acura 4WD MDX 6cyl Repair Manual ---
Jan 02, 2011 | 2002 Acura MDX
Radio code for acura MDx 2001
You will need to go to the dealer, they have the code that you need.
Jul 28, 2010 | Acura Car Audio & Video
My 2001 acura mdx driver side door won't close
THE DOOR CATCH HAS A DOUBLE "C" THAT HOLDS THE DOOR CLOSED. FIRST TAKE A SCREWDRIVER INSIDE THE "C". USING THE HANDLE ON THE INSIDE, PULL THE HANDLE AS IF YOU WERE OPENING THE DOOR AND AT THE SAME TIME, OPEN THE DOUBLE "C" WITH THE SCREWDRIVER. I HOPE THIS HELPS. THANKS FOR USING FIX-YA. PLEASE FEEL FREE TO KEEP ME POSTED. GOOD LUCK
Sep 02, 2009 | 2001 Acura MDX
61 people viewed this question
 Grubhead
Grubhead
