Question about Philips Magnavox MWR10D6 DVD Recorder
NOT ABLE TO RECORD
I AM TRYING TO RECORD VHS TAPE FROM A VCR TO THE DVD RECORDER AND I NEED SOME HELP. WHAT IS THE CORRECT SETUP WITH THE CORDS? NOTHING IS RECORDING.
  • 492 Answers
Key thing to remember when recording anything is the following: 1.  Color to color on the back of the machine      Video -yellow      Sound - White and red 2. Make sure your source is output and the recorder is input. 3. Be sure that it is original content that you are trying to record ie make sure you are recording from a VHS that is "Kids do Beauty and the Beast for 5th grade play" and not "Disney Beauty and The Beast"
Legal Copyright Info This information is intended for help with original work.  It is not intended for misue or copy of copyright materials.  Most DVD Recorders will not record protected content, but for those that do not provide copyright protection I assume no liability and will not be responsible for damages or legal action resulting from the misues of this information.
Posted on Jan 08, 2009
How to convert VCR to DVD
no easy way to do this unfortunately. You either need to connect your VCR to a DVD recorder and record it directly onto DVD or use a device such as this http://www.dx.com/p/easycap-usb-video-capture-adapter-5707 to connect your VCR to your computer and record it onto your computer that way.
Feb 23, 2015 | Zenith XBR616
In February, someone asked: "When
What are the tapes that you are trying to copy? are there genuine copies of films? YES THEY COULD BE COPY PROTECTED how they do that? simple they record the tape with the most minimum srength of signal, if you try to copy it you lose signal strength trough the copy process than the video looks a bit scrambled/discoloured and the sound is bad, if it's the case you could buy a video signal booster (if still available in stores) than you have to copy with a VCR that is separated from the DVD recorder so that you can install the booster from the output of the VCR to the input of the DVD recorder.
Hope it helps!
Jan 04, 2011 | Televison & Video
I cannot get it to record a vhs tape to a dvd. The vcr will play tapes and the dvd player will play dvds. I need some one to walk me through what buttons to push to record.
You need a remote to setup the dvd record and vcr record. Then you have to do dvd initialization perhaps before you can dub from tape to dvd?
Dec 20, 2010 | Toshiba DVR610 DVD Recorder/VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
Dec 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
Record vcr to dvd-r
This suggests that you are net setting up the DVD recorder up correctly,
Check- are you connecting to the correct 'INPUT; port?
Check have you select the correct chanell that points to this port.
Carefully go the the book- vey can be very dense to read.
Nov 21, 2007 | Zenith XBR413 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Logo
129 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
