Question about Lexmark Optra T610 Laser Printer
Always prints more to left than established margin
Any item sent to the Optra T610 is printed further to the left than the left margin established for the document. If you generate a document with equal margins and print it on this printer, the left margin turns out too narrow and the right margin too wide. The document will print out fine on other printers, but it is off about 4 letters to the left on the T610. Sometimes the document size is such that print or graphics on the left side are cut off, rendering the copy unusable.
    President:
  • 8,637 Answers
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
Posted on Jan 23, 2009
Prints ok but prints additional blank sheet after each complete document
Press menu button and scroll to the right and access the Finishing menu and select NONE for Separator sheets .
Please contact Lexmark Technical Support for further assistance.
Aug 19, 2011 | Lexmark Optra T610 Laser Printer
Optra T610
If your printer only prints black pages it will require the high voltage power supply to be replaced. this will fix your problem
May 01, 2010 | Lexmark Optra T610 Laser Printer
What are the steps to take a test print page on lexmark T610 optra
go to the printer and faxes right click the printer and go to properties and click on the tes page
Apr 29, 2010 | Lexmark Optra T610 Laser Printer
Lexmark Optra T610 prints distorted and broken text and images
try deleting the printer and drivers completely, then reinstall
Mar 11, 2009 | Lexmark Optra T610 Laser Printer
Our lexmark Optra T610 laser printer keeps telling me to "change tray one to plain paper"
verify paper tray is set for correct paper. print the configuration menu and check the paper size for tray 1. If it does not have right size, examine the tray bottom to see if slider is in place
Feb 03, 2009 | Lexmark Optra T610 Laser Printer
Optra T610 Print Problem
Your paper size settings for Tray 1 is probably wrong. Make sure it is set to Letter and the type is Plain Paper. If your Paper size is Universal, then either the paper guide in the tray is set wrong or the paper size sensor is broken. If the sensor is broken, you can disable auto paper size sensing so the printer will allow you to specify a paper size. To disable paper size sensing, you need to go into Config Mode. The other way is to send a PJL command to the printer to disable the function.
Nov 07, 2008 | Lexmark Optra T610 Laser Printer
Printing envelopes
you can replace the paper in the main tray with the envelopes. this is the only way unless you have a secondary paper tray or manual paper feed that does not override the main paper feed
Oct 03, 2008 | Lexmark Optra T610 Laser Printer
OPTRA T610 NOT PRINTING FROM TRAY1
What happens is that the rubber roller that's supposed to pick paper up and load it in doesn't pull the paper from the tray anymore, hence it gives the paper jam error message. If you want you can replace that rubber roller to fix the problem, however first thing I do is to take that rubber roller out (remove tray and look underneath to find the roller) and turn it inside out then fit it back. This will give the rubber roller the grip that it missed and solve your problem.
Jul 13, 2008 | Lexmark Optra T610 Laser Printer
OPTRA T 610 Lexmark printer.
It sounds like you are describing the pick arm or autocompensator. It also sounds like you have the printer turned on its right side for that to be on the left. The part you are looking for is part # 99A1056 for the Optra T610.
Nov 06, 2007 | Lexmark Optra T610 Laser Printer
Lexmark Optra T610 Laser Printer Logo
847 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
