Question about Canon imageCLASS D761 Copier
Canon copier D761's printer cartridge is jammed
Trying to remove the printer's toner cartridge but it stuck(jammed) on the right-hand side as your looking down at the printer cartridge from the right side of the printer. Printer works fine after clearing the jam but I cannot remove printer cartridge. One side moves up but the other side doesn't budge. I'm using a little more force then normal to remove but still stuck.
  • arlingtonp Jan 09, 2009
    With a little lead and some more force, I managed to get it out. It seems whoever had replaced it prior had force the cartridge down more then it should have been and somehow that force downward managed to jam it in. Thanks for the help Officetech. All is now well
  • Anonymous Mar 17, 2014
    mg2120 printer ink cartridge is stuck to the side
  • 100 Answers
That door above the cartridge needs to be open all of the way, maybe even push it back gentley to make sure. Should be at 90-92 degree angle. Then the cartridge will come out.
Posted on Jan 09, 2009
Toner cassette tray jammed
You'll need to remove the covers and find the release actuator slightly below and behind display/control panel. The actuator can then be taped so that the drawer will no longer get stuck, but when you replace a cartridge you will have to manually calibrate. Good luck!
Jan 06, 2014 | HEWLETT-PACKARD CP1525NW Laser Printer
PIXMA 450...Keep getting paper jam message and I can't see any paper bits anywhere. Trying to open the machine from the back to look inside. Have removed the 4 screws on the back and still can't remove...
Hi
The paper jammed can be found in the paper tray, remove the paper at the paper tray and inspect the roller for small pieces of paper jammed.
The paper can be found in the ink cartridge compartment, open the cartridge door and remove the ink cartridges, look for posibble paper jammer. Also once remove, check also the cartridge carrier if does not stuck up or jammed (cause this might me the problem). Turn off your printer and then move the cartridge head using your hand moving to the from right to left side and from left side to right side for 2-3 times. Move it gently.
Paper can be found in the rear access door if it is accessible. Inspect some paper jammed there.
Please let me know if you need more help
Mar 10, 2011 | Canon Pixma MP450 All-In-One InkJet...
How to install toner cartridge in a Canon 920
On your Canon PC 920, there is a recessed gray latch located on the left side of the machine towards the top front...press upwards on this latch to release the top part of copier (same as removing a misfeed or clearing a paper jam). The copier opens up.....now, located in the top unit, about center, is the drum / toner unit. It has a black plastic handle on it. Grasp this handle and pull towards you...slowly...until it is free of machine (support the rear of the unit with your other hand) Open new cartridge (unit) and install in reverse order (there should be instructions with the new cartridge) The copier has rails that the cartridge mounts on. Another note, before installing....gently shift the cartridge from side to side.....this distributes the toner evenly (again, covered in the installation instructions packed with the cartridge) There is a tab that needs to be removed to allow the toner to get where it needs to go for copying....attatched to this tab is a strip of plastic, pull all the way out. I have a PC 940...it uses the same cartridge.
Mar 24, 2010 | Canon Office Equipment & Supplies
Our toner cartridge is stuck in the loader and will not come out. How do you remove the toner cartridge?
push the blue plate/handle thingy located on the right side of the toner cartridge and push to the left..
Mar 18, 2010 | Canon imageRUNNER 5000 Copier
I have canon d761 3 years old. Suddenly don't work. No copy(no image) anything, but everything is good.
Hi.
If the printer does not even copy, then it is faulty, please perform the following troubleshooting steps before contacting Canon.
  1. Ensure that the Energy saver option is not on.
  2. Try disconnecting the power cord for five minutes.
  3. Check if a message is displayed on LCD display.
  4. Try removing and refitting back the toner cartridge.
If that does not fix the problem, then the printer is faulty, in that case contact Canon to locate the nearest service. Ensure that the energy saver light is not on.
See also:
red_arrow_greybk.gif Frequently Asked Questions
red_arrow_greybk.gif Support by E-mail
red_arrow_greybk.gif Support by Phone
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=9438#SupportDetailAct
Feb 18, 2010 | Canon imageCLASS D761 Copier
Paper jam
just remove all cartridge and u will find the stell plate wich is movable from there u can remove the paper
Mar 25, 2009 | Canon LASER SHOT LBP-5000 Printer
Paper jam in the fuser unit.
hi
first you must remove the side panel on fixing side and move the scanner unit to reveal a two hole at the top of the machine,total of 3 screw for fixing unit,and one of that screw in front side of fixing unit you must use small philips screw,and take care to remove the wire
Dec 13, 2008 | Canon imageCLASS D761 Copier
Paper jamb
you need a copier tech to fix it the fuser unit has to be removed to get jam out i done a lot of them and when some people try as you have to remove the jam they do more damage
Aug 20, 2008 | Canon imageCLASS D761 Copier
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Cannon image class d761 copier
Check under the toner cartridge for the jam.
If this help you, please rate me. Thanks, Patty
Dec 28, 2007 | Canon imageCLASS D761 Copier
Canon imageCLASS D761 Copier Logo
136 people viewed this question
old marine
old marine
