Question about AT&T Cell Phones
Unable to use phone, everyone is address book says not allowed
There is a line through my bars, did have a green A now shows a red D and a slash through my service bars. I have no service and unable to use since yesterday 1-7-08. I can't even directly dial anyone.
Found it was a service problem, the entire town was experiencing and back today. Thanks
Posted on Jan 09, 2009
My projector has lines on the screen. new bulb didn't help
If this projector is connected by Component Video (3 or 5 wires) instead of HDMI, the most common color related problems are caused by having one of the 3 video cables (Red, Blue or Green) with a bad connector. If everyone is a green smurf the problem is with the red cable. If everyone is a red smurf the problem is the blue cable. If the green was bad you wouldn't see anything.
Another possibility is if the green is plugged into the yellow jack instead of green jack on the projector, you could see what you are describing.
If everything checks out, take the projector to a repair facility.
If you are connected by an HDMI cable, (combined with the fact you mentioned vertical lines not horizontal) then take the projector to a repair facility.
All of this assumes that you don't just have a bad Cable Box or Blu-ray player or Home Theater Receiver. (The source)
Oct 01, 2014 | Dell 1210S Projector
Line 1 disconnects people on hold
Try these first and let me know
Intercom does not function correctly
• Make sure line 1 is connected properly and common to all phones on the system.
• Make sure all phone ID’s (station numbers) involved have been assigned.
Transfer does not function correctly
• Make sure receiver phones (stations) have same line connected.
Intercom indicator turns red and green alternately
• The station address needs to be re-assigned due to a duplicate station address in the system. See “Changing the Phone ID (Station Address)”.
Good luck,
Lee
Jun 17, 2008 | GE RCA 4-Line Speakerphone
Yahoo address book contacts no longer show when they are on line
call yahooCustomer Service Phone Number
1-866-562-7219 or 1-866-562-7228
Mar 25, 2013 | Yahoo Mail
Unable to transfer address book from galaxy ace to golf car
Try any app from the play store that allows bluetooth sharing of contacts
Sep 20, 2012 | Android Galaxy Ace
My tv sony kv-pg21n70 has horizontal white thin line about 2 inches and blue ,green ,red thin line under it
Go to this blog. Type this blog address to the address bar of your borowser and, press Enter.
electronicshelponline(dot)blogspot[dot]in
Insert Dots in proper place.
Apr 07, 2012 | Televison & Video
My screen reads "SIM not allowed MM#3", and in the upper right, next to the icon showing how many bars of reception I have, there is an icon of a phone handset with a red slash bar across it. I cannot...
This means you have no service in the place the phone is at.
You need to go somewhere where you get full service and try it.
power down,remove battery,replace battery, then see what it says when you are in a place that you would get good service.
Still have problem, go to your phone carrier and have them check the sim card and your service, it could be your shut down.
Feb 05, 2010 | Samsung SYNC SGH-A707 Cellular Phone
My address book is empty
go to u adress book where the names should be. press the MENU button then scroll to FILTER. when u get to that page press the MENU then scroll to CLEAR SELECTION. this happened to me also i hope that helps u out.
Aug 16, 2009 | RIM BlackBerry Bold 9000 Smartphone
When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there....
when battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
Jul 18, 2009 | Palm Treo 650 Handheld
Unable to view my Address book
This is typically caused by a filter being applied in the address book. Open you address book, press the BB menu button, and select filter. Once you are in the filter options, make sure that all check boxes are unchecked, then exit back out.
This may not be the cause of everyone's issue, but it may be a solution to some of the problems.
Another thing to check is if the contact are actually in the "Sim Phone Book" opposed to the regular address book. Open your address book, press the BB menu key, and select "Sim Phone Book". After doing this, you may see all of your contact in there and you should be able to copy the contacts to the BB.
Aug 18, 2008 | RIM BlackBerry Curve 8310 Smartphone
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Cell Phones Logo
62 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
