Question about Philips DivX Ultra HTS6500/37 Theater System
Need installation instructions for phillips divx ultra
Don't know if i have the right wires to the right colors going in the right holes. do i need an rf modulator? an s-video wire? The back of my tv only has the screw-in cable hookup. right now all i get from the player when i put in a dvd is "no disc". HELP!!!
    Sniper:
  • 51 Answers
Please tell me the exact problem what you having????
With DVD player Or With TV???
If at all you are getting "no disc" on your player its due to Disc compatible mean to say that Not supporting.
If at all there will be a Player Lens Problem.
Posted on Jan 09, 2009
Wiring of 2 ge ultra max t8 ge 332 max-n/ultra ?
This section is for computer questions not lighting.
Apr 17, 2013 | Computers & Internet
2007 BMW 328i IAT Wire Colors in MAF Sensor
If you are installing a so called "chip" don't do it, it can harm the engine due the changes it causes in fuel control as related to Intake Air Temperature and burn holes in the pistons. All that little part really is, is a $.50 (50 cent) resistor that you can buy from Radio Shack, it is smoke and mirrors and it also will void any warranty you may have. I for one strongly advise against installing it, it will make not difference in power and all there claims are just lies and falsehoods..
Jun 08, 2012 | BMW Cars & Trucks
Does any radio work for a 1986 camry?
As in aftermarket like a Sony or Kenwood or..???? Yes.
The easiest way to install one is to get an installation kit. One that has a bracket/face that fills the hole in the dash and the new radio sits in and a wire harness. The harness makes things so simple. You don't need to know what wire color is what. The cars factory harness plugs right in and the new radio wires will be the same color on the harness.
Sep 06, 2011 | 1986 Toyota Camry
I am 99% sure I have a bad fan. TV was turning off (probably overheating). We replaced the lamp (for the fourth time), but the fan continues loudly when the set is turned on. Question-- Can I replace...
Tools/Supplies:
• Phillips screwdriver (magnetic tip)
• 1/4" nut driver
• 1/4" wrench, small adjustable wrench, or stubby Phillips (to access screw in tight spot)
• Canned air with extender tube, a few cans
• Optical-quality microfiber cloth
• Clean, lint-free cloth
• Small brush
Precautions:
• Do not use any cleaner that contains ammonia. A clean lint-free cloth dampened with water was adequate for me.
• To prevent over spray, do not spray any cleaner directly on to any TV part. Spray on to rag only. (I only used a dampened rag to clean plastic and metal surfaces; no electronics or optical surfaces.)
• Use only an optical quality microfiber cloth and/or canned air to clean the light engine lens, the mirror and the inside surfaces of the front screen.
• Exercise caution using canned air. Do not tilt the can and allow any liquid propellant to escape. I had a few full cans available, and swapped to a new can often.
• Keep screws removed from each panel in a different cup. Most are different sizes.
• When disconnecting wiring connectors, note color codes for connector orientation when reconnecting. Most connectors only install in one orientation, but it's not clearly obvious.
• If contacting any circuit boards/wiring connectors, make sure to touch the metal frame first to discharge any static charge.
Disassembly Instructions:
1. Insure TV is powered off and allowed to cool at least 2 hours (overnight if possible).
2. Open and remove the Lamp Unit door on left side of TV. Using a Phillips screwdriver, loosen the 2 screws on the lamp unit and carefully remove the lamp unit.
Clean lamp unit, using microfiber cloth on the lens and set aside for reinstallation.
3. With the lamp unit removed, you can see the light engine's color wheel through the small hole. I covered this hole with tape to prevent any dust from entering during my cleaning.
4. Remove the lower rear cover (2 screws on each end and 9 along the back panel).
5. Remove the cover from the Input/Output jacks by removing the 7 silver screws securing the cover to the Input/Output modules and sliding the cover off the power cord grommet.
6. Remove the front pedestal cover as follows:
Note the blue, red and grey wire harnesses on the right side leading to the front panel controls, AV-3 jacks and PC slots. Loosen and remove these wires from their wire ties.Grasp the pedestal cover at the ends and gently pull outward. It is installed with quick-release pins and should release easily.Gently pull the pedestal cover out, being careful to guide the wiring.Carefully disconnect the 3 wiring connectors, noting the color code for reconnection.In preparation of removing the front screen, 2 hidden screws must be removed. These 2 screws secure the bottom corners of the front screen and are installed from the back.
7. Remove the plastic housing where the lamp unit was removed:
Loosen the wire tie and remove the wires from the top of the plastic housing (these wires go to the lamp door switch).Remove 2 screws securing plastic housing. One on left side and other in base on right side (with limited space available, will need 1/4" wrench or stubby Phillips).Slowly pull housing from TV, until you can reach the connector to the lamp door switch. Note color code and disconnect wiring connector (may be easier to pull some wire through the hole and lift upward to remove connector).The front panel screw can now be seen in a recessed hole. Loosen this screw. (I did not remove the screw completely, to aid in reinstallation. Otherwise, a magnetic Phillips screwdriver may be needed.)8. From the area of the front panel wiring ties the other hidden front panel screw can be seen in a recessed hole. Loosen this screw.
9. Remove 11 of the 12 screws along the back of the TV securing the front screen, leaving one loosely installed at the top.
10. Remove 4 of the 5 screws on the front of the TV, at the bottom of the screen.
11. While holding the screen at the top and bottom, remove the two remaining screws, and gently lift and pull the front screen panel away from the TV.
Store the front screen assembly where the inside surfaces can be cleaned with the microfiber cloth and/or canned air.
12. Reassemble the TV in the reverse order, remembering to remove the tape from the hole covering color wheel, if installed earlier in step 3.
There are 3 fans to clean:
The large Lamp Fan behind the lamp and light engine assemblies is clearly visible.There are two smaller fans mounted next to each other. One fan is mounted between the cable card slot and the light engine and the other fan is mounted just to the right directly on the light engine assembly. It's somewhat inaccessible without removing the light engine, but using an extender tube on your canned air, it is easily cleaned.
The lens of the light engine will have the most dust. Clean with canned air and the microfiber cloth. Use a corner of the cloth to reach beneath the plastic tabs covering the lens.
The mirror may have a few dust particles. Gently wipe with the microfiber cloth and use canned air. Hope this helps,
TechGuy21
Jul 04, 2011 | Toshiba 62HM95 62" HDTV
I need to replace the door switch on my GE Profile Gas Dryer DPSB620GC4ww and don't know how to get behind the panel on the front of the dryer. Can you give me detailed instructions on how to do this?
unplug it,open the door and look up,you'll see two phillips screws,take them out and remove the top panel,if you want to remove the front panel just remove the two phillips screws one on each side of the panel around 4 inches down from the top.
May 20, 2011 | GE Profile DPSB620GCWW Gas Dryer
I have a Thermodor SCD302ZP Double Convention Oven. Does the lower heating element come out from the front of oven or do you need to gain access to rear in order to test/replace it? I removed the...
that model number doesn't come up.first make sure the power is off to the machine,you have 240 volts going to that element,all the thermodor ovens i worked on come out from the front,there should be two phillips screws holding it in place,remove the screws and pull the element forwards,some of them you have to lift the element up the end that goes through the wall is bent up so the wires don't hit the metal wall behind it.on some the wires are very short so don't be surprised if they pop into the hole on you,try to hold it with a needle nose,have the other element in there and stick the wire right on the new element so you don't loose the wire into the hole,if that happens you might have to pull the oven and remove the back panel.good luck and i hope this helps you
May 11, 2011 | Ovens
I have wasted 4 hours with 1 of your so called (experts) i want answers not excuses
Don't know if I can help or not, but this what I do.
I've downloaded the DIVx player and converter software (free) to my computer. I can download mpeg, avi movies, etc, and convert them to DIVx format if I need to. The DIVx player has a 'burn' feature that is fast and burns them in a DIVx format. My old DVD Recorder will not play DIVx format but my 'cheap' Phillips will. I just keep it hooked up to my old DVD recorder through the front RCA input jacks. When I want to play a DIVx movie and watch it on the TV, I use the cheap Phillips player. I have to change the input on my old DVD Recorder to 'Front Input. I usually record the movie on a DVD R in my DVD Recorder while I'm watching it if I want to keep a copy to play later on the DVD Recorder. Most of the time, I burn the movies to RW DVD and erase them later.
I don't remember the web site for the DIVx players and converters, but you should be able to find it with a search.
Hope this helps.
Jan 16, 2009 | Televison & Video
Stereo wireing color codes for 2004 suzuki forenza
you are a ******* idiot you+this answer= you are ******* stupid we don't want to know what our best bet is you damn inbred **** we want color codes!!!!! God you are dumb what color means what its like putting the caps back on the right markers in your coloring box with your little books that you cant even color inside the lines cause you are so stupid!!!!!!
Dec 09, 2008 | 2004 Suzuki Forenza
Wiring
Click the link listed below that will take you Gigabyte. Download the manual described as, (English-Rev. 1103, format pdf, size 7.47Mb). The case leds placement is on pg. 25. USB's on pg. 27. Everything you need to setup this Ultra motherboard is here.
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=1621
The only thing not mentioned for connecting the case led wires to the motherboard is the wire colors. Which is, pos+ & which are neg -. Usually white colored & black colors are negetive -. Other colors like Green, Blue & red are pos+.
This should make it much easyer to install.
please vote...
Feb 13, 2008 | Mercury P4VM800M7 Motherboard
HP 95 Tri color inkjet cartridge refill
Yellow Top
Megenta, Bottom Left
Cyan, Bottom Right
(leave the middle two holes alone)
Jan 05, 2008 | Office Equipment & Supplies
Philips DivX Ultra HTS6500/37 Theater System Logo
166 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
