Belkin F8E825 USB Mini Wireless Optical Mouse Logo
andrew anderson Posted on Jun 02, 2007
Left mouse button keeps clicking
My wireless mouse repeatedly keeps clicking the left mouse button even when I don't press the button. This makes it impossible to use. I have installed the driver and turned it on and off several times but it still keeps doing it. What can I do?
Anonymous
Level 1:
  • Contributor 35 Answers
  • Posted on Sep 22, 2007
Anonymous
Contributor
Level 1:
Answers
35
Questions
0
Helped
15556
Points
40
Could be the inside button that is defective and causing false contacts try to open the mouse and check that button
3answers
Adjust letters repeating
Key could be stuck on keyboard. Try banging on all the keys (not hard enough to break - just hard enough to unstick). Try a different keyboard.
1helpful
My HP Optical mouse Left Mouse Button has stopped working. The RMB still performs its function (so batteries on mouse still OK etc). I have tried shfitng the USB port etc but nothing seems to fix the...
Similar problem which I resolved today.
I have a hp wireless mouse model no. 5189URF. I bought this in hp online in April 2009. It needs 2 x AA Alkaline batteries.
Steps I did to resolve.
1. Removed battery cover.
2. Removed batteries below which 2 screws exist.
3. Remove 2 screws and remove the top casing of mouse.
4. You can see 2 very small square push button corresponding to left and right clicks in mouse.
5. try to press the left button and make sure its free. The issue seem to be that this button becomes rusty internally and lost contact. Therefore clicks are not recognized. You may need to press it repeatedly and also with a slight thrust circumferentially.
6. You can test your mouse in WIndows Help & support option linked with HP hardware diagnostics tool.
3helpful
2answers
I bought a mouse (HP Wireless Optical Mobile Mouse (VK479AA)) and I can't hold down the keys. By that I mean when I hold the button down, it isn't held, instead, the computer thinks I'm constantly pressing...
I have the same problem. I posted on HP forum but did not get any help. I contacted HP technical support. They sent me a new mouse but it behaves the same way.
Non responding wireless mouse and keyboard
mcdevito75 here, Sounds like the mouse itself is faulty, if the right button when depressed returns to position and you hear the familiar click, and you don"t hear that from the left button, then the mouse itself is faulty, ask Dell to send another mouse, it should be on warranttee with your new computer.
How do i can et internet on my laptop xp to connect from wireless router it show a lock how can i unlock
Step 2: With the left mouse button, click on 'Control Panel'.
Step 3: With the left mouse button, click on 'Network and Internet Connections' (Network Connections, if in Classic View).
Step 4: With the left mouse button, click on 'Network Connections'.
Step 5: With the right mouse button, click on the 'Wireless Network Connection'.
Step 6: With the left mouse button, click on 'Properties' button.
Step 7: With the left mouse button, click on the 'Wireless Networks' tab.
Step 8: With the left mouse button, click on the name of the wireless network, under 'Preferred networks', that you want to automatically connect to.
Step 9: With the left mouse button, click on the 'Properties' button.
Step 10: With the left mouse button, click on the 'Connection' tab.
Step 11: Ensure there is a checkmark in the checkbox, next to'Connect when this network is in range'.
Step 12: With the left mouse button, click on the 'OK' button.
Step 13: With the left mouse button, click on the 'Advanced' button.
Step 14: With the left mouse button, click to select 'Access point (infrastructure) networks only ' (This will help prevent your connection from bouncing around from one network to another).
Step 15: With the left mouse button, click on the 'Close' button.
Step 16: With the left mouse button, click on the 'OK' button.
2answers
The left click is not consistently working
you should change your mouse cuz only left mouse have this physicall problem due to extra pressure or hard clicks on it.mouse is sensitive device so repair is not better option.just change it.
3answers
We moved the computer and are currently trying to reconnect the mouse and keyboard. THere are instructions on the keyboard which we followed but the keyboard will not connect to the wireless device. Any...
check the bottom of keyboard and wireless pickup device..lights should be steady on..if not, reset with buttons..also, check battery charge, by replacing battery..also re seat the wireless pickup into another usb port.
4helpful
2answers
Microsoft Wireless Notebook Optical Mouse Not Connecting
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Microsoft Wireless Laser Mouse 6000 (Model 1052):
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. Put the pointer on the left button and then go to the drop down and make sure the buttoon is set properly.
Hope this helps. Bud
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
