Question about Dell 810 All-In-One InkJet Printer
810 all in one printer pulls paperto the right at start and jams
Fedds paper to the right at start and jams,
  • juneandgord Jan 09, 2009
    unpluged, cleaned feed roller with very small amount of rub alcohol pad taped to popcical stick turn printer upsidow and then on left side gave it a pat or two, reached in and moved roller back and forth....paper is feeding in fine now and printing .
Unplug printer
Then put very small amount of rub alchol on swab taped to long popcical stick
rubbed it lightly back and forth over roller to clean off any unidentifiable residue,
turned printer on left side down
gave it a couple of hard taps on right side where roller is situtated
reached in with fingers and moved roller back and fourth
Repluged it in set it up and now prints ...
Posted on Jan 09, 2009
Printer Paper Jam
Look in the user manual first. If no help there Google with pointed info. The item model number and other pertinent info
May 06, 2015 | Used Epson Artisan 810 All In-1 Wifi...
Paper pulls to right side and then jams it all started when paper jam i pulled it out and ever since then when loading paper it pulls to the right and then jams
Try running a good sized thickness paper thru it to clear out the cutters.
Sometimes when they jam some residual paper is left in the space between the cutter wheels and causes the paper to feed askew...
I use the cover from old phone books.
Sep 29, 2011 | Office Equipment & Supplies
I had to clear a paper jam in my Artisan 800 printer. i followed the instructions and cleared the paper, but when i turned the printer on the the screen continued to flash and indicate error. the paper has...
This problem is usually caused by the CR Scale forced out of it's **** by a paper jam. The CR scale is a 1/4" wide strip of grey plastic band that is visible when you open the printer. It is right above the serial number. Slide the head carrier to the left and look behind the head carrier. You will see a small U-shaped plastic piece. Make sure the CR scale is within the **** or u shape. Be very careful not to damage the CR scale as you slip it back it. When this scale is flipped out of the ****, the printer head slams into the right side of the printer on start up (twice) and produces the fatal error message, with the paper jam note.
Mar 24, 2010 | Epson Artisan 800 All-In-One InkJet...
Paper jam. paper pulls towards the right hand side and jams
Sound like you have something stuck in the paper feed path, check for a paperclip or similar, it may be that you have had a jam and torn off a piece of paper inside the printer which is now stuck, when removing jams from any nmachine allways pull paper in direction of feed never back on itself as it can cause this very problem
Dec 03, 2009 | Dell 810 All-In-One InkJet Printer
Paper jam in printer
Dear
It is the problem paper end sensor is open or fedd sensor is open.
power on then paper jum it is the same problem. or power on printer is ready after print command then paper jum it problem your cartridge chip is diable or feed claught is not active
Jun 17, 2009 | HP Color LaserJet 5550dn Q3715A Workgroup...
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Paper Jam
try these steps
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Feb 14, 2009 | Dell 810 All-In-One InkJet Printer
HP psc 2350
You need to reintialise the printer again from the scratch. turn off your printer and disconnect from the computer. Uninstall all the drivers and application of the printer. reinstall the driver by following the instaruction. Connect the printer cabel to the computer when it prompts you to do that and then align the printer cartridge. The paper fedd will work fine
Oct 07, 2008 | HP PSC 1210 All-In-One InkJet Printer
Fedd paper and paper jam
The paper used for printing should not be wet, torn or folded from any side as this can cause paper jam, hence resulting in carriage jam. Also, use only one type of paper at a time while printing. The paper should be added to the In-tray only when the printer is not in use. Make sure not to overfill the In-tray.get more information
http://h30434.www3.hp.com/t5/Other-printing-questions/Printer-Paper-Jam/m-p/126558
Jul 01, 2008 | Office Equipment & Supplies
Dell 810 All-In-One InkJet Printer Logo
91 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
