Question about GE JKP30WMWW 27" Built-in Single Electric Wall Oven with Dual Element Bake & Electronic Oven Control...
Oven makes a noise when I turn it on.
I have a GE wall oven about 12 years old, not sure of the model, and it has started making a squealing noise when I turn it on, or shortly after I turn it on.
  • e_charbonnea Jan 11, 2009
    Now the question, how do I fix the fan....? :-)
    Can I do it myself...should it be repaired by a professional...or should I get a new oven??
  • GE Master
  • 3,463 Answers
If it is a fan assisted oven , then it sounds like a noisy oven fan.
It could be a worn or dry bearing in the fan motor. if you open the oven door , you should be able to tell if it is the fan by listening to it carefully.
The other possibility is if it has a cooling fan in the back or on the top of the oven, it could also be that causing the prob, these are about the only things that could be making a noise, as there are no other moving parts that could make a noise.
PLz rate my solution.
Thanks.
Posted on Jan 08, 2009
Desperately searching for User Manual for Tappan Wall Oven Model 12-4990-00-04.
Hello Owner, thank you for your inquiry!
I understand that you need the use and care manual for your Tappan wall oven, 12-4990-00-04. If the model is older than ten years old manufacturers will not keep that information available. You might be able to perform a search for antique models online for any additional information. -Matt
Jan 11, 2016 | Frigidaire Ovens
How do I replace the temperature controller in GE model P7 oven?
should be easy make sure u unplug from wall then in the back panel u can unplug after making sure to note where wire plugs are connected and ifinite switch can usually be removed by removing the screws holding it. remember to remove the knob from other side
Mar 08, 2015 | GE Ovens
I have a 40 year old Tappan electric wall oven. It has an analog clock with 3 timers on it (2 small timer...stop and start and a large timer with 3 hands on it). Which position do the timers need to be for...
I have one of these too. the TOP small clock should be set to the time you want the oven to start and the BOTTOM small clock should be set to the time you want it to turn off. Be sure to set the oven settings to what you want and the correct temperature.
Try testing it first just to see if it works correctly. It's also important to make sure the other large clock on the oven is set correctly.
May 01, 2010 | Ovens
I need to replace the "Glow bar" in my 35 year old tappan gas wall oven. Is this something I can do without taking the oven out of the wall?
Hi, As long as the wires connecting the ignitor are long nough, you can do this while the oven is in the wall. They usually come out far enough. Make sure the oven is unplugged or the breaker is turned off. It is fairly simple to change.
Please let me know if this helps you or if I can assist you further.
Vic
Jul 11, 2009 | GE 24" Built-in Single Electric Wall Oven...
Convection works but Microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
duid
May 26, 2009 | GE Monogram® ZMC1095BFBB /...
try using a voltage stabiliser .it may just solve ur problem..
May 17, 2009 | GE Monogram® ZMC1095BFBB /...
JTP15 GE Oven - vibration noise
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Jan 14, 2009 | GE JTP15 Electric Single Oven
Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Dec 27, 2008 | GE JKS05 Electric Single Oven
GE Electric wall oven
Not sure I can help you but will certainly try. Certainly sounds like the heating element - if not possibly a blow fuse. If you have a tester as in a light tester or proper electrical tester you should be able to turn the element on and test to see if it is getting power. If it isn't it may well be a fuse in the wiring. A lot of ovens these days do not have fuses and rely on the mains having a Safety Switch. Taking this into account I would say it is the element which you will need to remove so you can obtain a new one. With elements on most ovens you have to remove them from inside the oven and sometimes have to remove the back panelling to get to the wires to disconnect them. When you do make sure the power is turned off. Hope this helps.
Regards
Bryan
May 31, 2008 | GE Profile JTP18 Electric Single Oven
GE JKP30WMWW 27" Built-in Single Electric Wall Oven with Dual Element Bake & Electronic Oven Control... Logo
2,235 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
