BellSouth 1080 wp  2-Way Radio
Problem for BellSouth 1080 wp (15 Channels) 2-Way Radio
Poor transmission
By Milan on Jun 02, 2007
Ever since I purchased the 2 units the transmission is hard to understand. I purchased these some time ago and I just put them on the shelf and forgot about them. Now that I have a need I tried them again Doesn't work any better than the first time - even with new batteries - no matter which channel I use.
Any suggestions? Or would it be more cost effective to trash them and purchase new ones? It seems to cost more to fix things now days that to purchase new.
Please advise.
Thank you.
Milan
Solution #1
posted on Jul 06, 2007
Not Rated)
Bushwacker
Rank: Master
Rating: 86%, 16 votes
Its hard to tell exactly whats wrong without some more detail. I am assuming that these are 15 channel FRS walkie talkies?
If they are than what you have is 2 FM 2 way radios that operate in the 450 mhz region. FM is usually really clear at both close and far distances. With AM radios its possible for the transimission to be distorted at close distances.
First you want to check if this is a transmit problem (tx) or a recieve problem (rx). The easiest way to do this is to listen to other peoples transmissions and see if you can undertand them and if they are clear. Push the monitor button or whatever function there is on that particular radio to turn the squelch off. What you want is to hear static so you will be able to hear other people talking on other handhelds that are using different tones than you or might be too far to break squelch. You want to hear everything.
Check how other people transmissions sound..... if they are hard to understand like a transmission from you other handheld does. If the other radios you pic up sound clearer....try using yours again.... but give it some distance...
The speakers in these thing are not the best to begin with. Try that out and let me know your results... try to desribe what your hearing in detail.... like "garbled" "distorted" "low audio" stuff like that so I get an idea of what your hearing.
Try it out
Was this helpful?
Yes
No
Popular Solutions for BellSouth 1080 wp 2-Way Radio
Questions and Unsolved Problems for BellSouth 1080 wp 2-Way Radio
Do you recommend BellSouth 1080 wp (15 Channels) 2-Way Radio?
Answer
Answer
Hi , we have a Furuno FS1552 HF radio, that our tech tells us we need a U16 IC(intetrated circuit)... (More)
Answer
Hi, I bought a pro tekk uhf two way radio and thought I could use it with another uhf radio of a... (More)
Answer
ustrying to use my radio at work, to comunicate with motorola 22 channelradios and uniden 22 channel... (More)
Answer
have bellsouth hand held radios, model 2730, but when the person who is talking to the other person... (More)
Answer
My units have never really been used, but one has a very weak channel display. The other is fine. Is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top 2 Way Radio Experts
Top Telephone Repairmen
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
