Question about Toshiba 24AF42 24" TV
Is my Toshiba TV digital or analog?
Does my Toshiba TV, model # 24AF42 have a digital tuner built in. or will I need a converter box to receive digital TV signals after Feb. 09
  • 33 Answers
If there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Posted on Jan 08, 2009
Do I need a digital converter box to recieve a digital broadcast with a Sharp LC-20SH4U TV?
Yes you need a digital converter box. Your model has an NTSC Analog Tuner. It doesn't have a Digital Tuner. This is why you need the converter box.
For example, many companies like Comcast or Time Warner or TCI etc used to broadcast Analog Signals through their wires. Now they have broadcasted only Digital Signals. This makes either your TV Obsolete as a Tuner or you have to get a digital converter so your Analog TV can receive the signal.
Depending on your service, it may be worth your while to get a TV with a digital Tuner.
Then again, it also depends on if you are connecting a box receiver to your TV. For example, if you have Directv or Dish, you would then use your standard Video/Audio or Composite Cables to transmit your signal OR your Out to TV Coaxial whichever works for your receiver. Some receivers have already built in converters . You should really consider all the factors to decide and determine it based on the type of service you have or want.
Mar 09, 2011 | Sharp LC-20SH4U 20 in. EDTV-Ready LCD...
I have a nspdp42 plasma and i cant affort cable and want free tv. is there a analog to digital converter in the unit already? the model # is 801rmd2237770 Thank you
The Insignia NS-PDP42 Plasma HDTV has a built in ATSC/NTSC/QAM tuner.
In short, yes, it does have a digital converter built in, but you will need a antenna capable of receiving digital broadcasts. You can find these at Walmart for $15 to $60.
Mar 05, 2011 | Insignia 42" Flat-Panel Plasma HDTV
Will the Toshiba Model 36A42 work without a converter box?
The short answer is no. The reason for that is because it's an analog TV and has a standard tuner which is now obsolete because of the changes to all digital programming last year. You won't be able to use it with out a converter box. I won't recommend a particular brand or model, that would be your choice. Here is a selection of "boxes" available.
http://www.google.com/products?client=firefox-a&rls=org.mozilla:en-US:official&channel=s&hl=en&q=Digital+to+analog+converter+boxes.&um=1&ie=UTF-8&ei=GVSxS9WXE4-CswPd27XKAQ&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CC8QrQQwAg
Mar 30, 2010 | Toshiba 36A42 36" TV
Does the JVC AV27230 require a digital to analog converter?
if you are going to continue using the rooftop antenna, then you will nee to purchase a digital converter box. Those television sets are only analog. You do have an option to get Directv or Dish network and you will not need a converter box at all. Directv and Dish network are 100% Digital and the receivers work as converter boxes for that product only.
Jun 16, 2009 | JVC AV-27230 27" TV
Built in tuner not working since digital transition
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
May 27, 2009 | Protron PLTV3250 32 in. LCD Television
Toshiba Color TV CF306 - Can it receive digital, with converter
The short answer is yes. The method is to set the TV to receive either channel 3 or 4. The converter will receive the digital broadcasts and "re-broadcast" them on either 3 or 4 analog for the TV to receive.
Let me know if you need anything else.
Dan
Mar 14, 2009 | Toshiba Televison & Video
How do I tell if my tv is analog
Hi Dru,
Good news, your 42 inch Phillips has a built in digital tuner, all you need is an antenna.
Please post the model of your other Tv and I will check on the tuner type.
I have provided a link to a site that has good info on antenna types and the channels you will be able to recieve.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this was the information you requested and please rate this solution.Lone99star
Jan 25, 2009 | Philips Magnavox 42MF521D/37 Television
Is converted box necessary for Toshiba 27D46 tv
The Toshiba 27D46 has a digital tuner, so you should be good to go when the switch to digital occurs.
Dec 18, 2008 | Toshiba 27D46 27" TV
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Jerry
Nov 07, 2008 | Televison & Video
Philips CCB130AT02 TV/VCR combo
Is this an Analog TV? Does it have a picture tube and not an LCD or plasma screen? Most likely this is a Analog TV.
If it is an Analog TV (and I would bet that it is), then no, it does not have a digital (QAM) tuner to pick up DTV broadcasts. The fact that it has a VCR also indicates that its an Analog TV.
If you are picking up your TV signals from an outside antenna and not cable, then yes, you will need a converter box to convert the new digital signals to Analog so that you can continue to use your TV set.
If you are using cable to receive your channels, the cable company already provides the conversion for you and your TV will continue to work as before.
The government is giving out coupons to help consumers defray the costs of purchaing a converter box. The following sites are good places to obtain more information.
www.ntia.doc.gov/dtvcoupon
www.DTVanswers.com
- Jim
Feb 06, 2008 | Televison & Video
Toshiba 24AF42 24" TV Logo
4,382 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
