Power loss Hi my computer is shuting off when windows loads and if i start right back up then it might shutoff before it gets to windows or it loads windows and shuts off again . Tech people from alienware told me it was a power supply issue so i put a new power supply in and i still have the same problem. i have a Foxconn nforce 590 sli motherboard D-Athlon 64 x2 5600+ am2 nvidia geforce 8800gts 320 mb now on the motherboard when it is just pluged in and not on there are 2 amber lights when i turn it on 2 green lights come on right next to them then under that and to the left there is 2 led letters FF lit up. please help !!
  • 7 more comments
  • tamejnta Jan 08, 2009
    powre supply starts up for about 2 -5 seconds then shuts down
    nothing appears on the screen.
    When power supply is connected to a meter it shows all voltages present.
  • asbillseesit Jan 08, 2009
    now i cant even do that when i start it now nothing shows on screen and there is a loud ring like a smoke detector
    no beep codes just a steady sound
    ok now i am getting a low tone beep every 5 seconds
    oh and now my motherboard says C1 on the little display under the video card
    ok motherboard says FF again and back to the first problem loaded windows and shut down then ran for about 5 seconds and shut down
    oh an before anything else thank you all for your help
  • FirstBlade
    FirstBlade May 11, 2010
    tamejnta, Do you get any beep codes?
  • FirstBlade
    Start in safe mode. Look at event viewer. What errors do you see?
  • 22 Answers
Check your expansion cards and memory to make sure they is seated properly. Remove any expansion cards you do not need. Did you replace the memory recently?
Posted on Jan 08, 2009
  • FirstBlade
    FirstBlade Jan 08, 2009
    Remove video card and reseat. If you still get C1 then replace video card.
    Problem Solver:
  • 12 Answers
Have you folks removed/installed memory with the computer plugged in ... but not powered on ???
newer systems maintain standby power on the memory .. if you have .. you could have blown a DIMM ..
I'd remove all installed memory .. then power up and see if the systems behaviour changes .. if it does .. and your system supports it .. add a stick of memory at a time untill you recreate the problem ..
  • David Brenchley Jan 08, 2009
    The codes your seeing C1, FF, ect indicate various stages of the POST (Power on Self Test) .. if your able to load windows this indicator is probably of no concern. I'd still suspect memory
Eng start butcut when accelersting
Lack of fuel to air ratio. Check for vacuum leaks, or clogged fuel filters. Also may include TPS, MAF, MAP senors which measure air so that the computer and add proper amount of fuel to that air. (CHECK EGINE LIGHT ON?) The throttle also has a kick down function either via cable or wire which shifts the transmission down when accelerating, if this is not happening it may cause power loss under load and even shuting off in the right conditions.
Jan 11, 2016 | Cars & Trucks
Electrical power loss
I'd check the alternator and the grounds.
Nov 21, 2013 | 2001 Ford Windstar
1994 Mazda PU Truck sometimes won't start if shutoff for 5-10 minutes.. Several tries later, it will start. spark seems ok, it gets enough fuel for a second, but then poops out. fuel pump shuto
Well there is no shutoff relay, but there is a fuel pump relay that powers the pump.
I would check it first. The computer grounds the relay for 3 seconds when you crank the engine to boost fuel pressure. Once the engine starts the pump is powered only if you have oil pressure.
Apr 12, 2013 | Cars & Trucks
Describe your sony vaio PCG-C1VRX/K Problem: O/S not found...cannot enable usb/cd use to fix/load new O/S
What do I do if the message "Operating system not found" appears when my computer starts, and why won't Windows start? ? Make sure the computer does not have a "non-bootable" floppy disk in the floppy disk drive (if applicable). ? If a non-bootable floppy disk is in the drive: 1. Remove the floppy disk. 2. Restart the computer and confirm that the Microsoft® Windows® operating system starts properly. ? If Windows still does not start, follow these steps to initialize the BIOS: 1. If there is a disk in the floppy disk drive, then remove it. 2. Turn off the computer. 3. Remove any peripheral devices connected to the computer. 4. Restart the computer. Page 1475. Press F2 when the VAIO logo appears. The BIOS Setup window appears. 6. Press the Right Arrow key to select the Exit menu. 7. Press the Down Arrow key to select Get Default Values. The message Load default values for all SETUP items appears. 8. Press Enter. The Setup Confirmation window appears. 9. Select Yes, and press Enter. 10. Select Exit (Save Changes), and press Enter. The Setup Confirmation window appears again. 11. Select Yes, and press Enter. The computer restarts. What do I do if my computer stops responding? Why can't I turn off my computer? It is best to turn off your computer using the Turn Off Computer option on the Microsoft® Windows® Start menu, located on the taskbar. Using other methods, including those listed below, may result in loss of unsaved data. ? Click Start on the Windows® taskbar, select Turn Off Computer, and then click Turn Off. ? If your computer does not turn off, press the Ctrl+Alt+Delete keys simultaneously. When the Windows Task Manager dialog box appears, click Turn Off from the Shut Down menu. ? If your computer still does not turn off, press and hold the power button or slide and hold the power switch until the computer turns off. ? If your computer stops responding while playing a CD or DVD, press the Ctrl+Alt+Delete keys simultaneously. You can turn off the computer from the Windows Task Manager. Pressing the Ctrl+Alt+Delete keys simultaneously or turning off the computer with the power button or switch may cause loss of data. ? Remove the AC adapter and battery.
Dec 13, 2010 | Sony VAIO PCGK45 PC Notebook
Dell Inspiron 1501 Black Screen
When you power up and everything finishes loading right click on screen and the personalize screen will appear .click on screen saver and to the left of the screen you will see a list that says change when computer sleeps you can reset the time there .Good luck
Jan 04, 2010 | Dell InspironTM 1501 Notebook
Weird power issue...I think.
it can be a bad power suply ,just try replacing it. IF it dosent work check your hdd
Jun 15, 2009 | E-Machines eMachines Desktop PC
Starting up the shuting right down
Viral infection is most likely the cause. Did you either recently install or update an antivirus program, or use one of those "remote fix your computer" services? Can you take the computer to safe mode?
Mar 07, 2009 | HP Pavilion dv6000z Notebook
Computer do not turn off
You have a System file problem
Go to C:\ right click go to properties tools "error check" click to open then tick little box to fix errors and reboot .
Windows on reboot will scan disk and fix any errors.
If this does not fix it reinstall windows in "Repair Mode"
Boot from Win CD after drivers etc are loaded will ask you what you want to do Press the R key to Install in repair mode. you will not lose any files doing so
Nov 03, 2008 | EPoX EP-8K9AI Motherboard
Lap top ceeps on shuting down half way threw start up no power at all.
either missing files on boot sector or a virus. try loading the windows cd and boot from it and repair boot sector or format and reinstall windows if boot repair doesnt work.
Apr 06, 2008 | Computers & Internet
Computers & Internet Logo
602 people viewed this question
David Payne
David Payne
