It use to work fine untill I started messing with the laptop fuction for switching sreens
Looking for Dell service Centre in chennai?get in touch with the laptop shoppe the best dell laptop service centre in chennai,the one stop solution centre for all your laptop queries and we ensure your laptop is repaired and it can smoothly within minimum downtime.
SOURCE: my dell latitude d820 laptop
If you have forgotten the Windows password:
A forgotten windows password can be problematic.
If you have windows XP HOME edition, boot to the SAFE MODE (Press F8 during boot to get startupmenu) select the ADMIN account (Password should be blank) Once inwindows, go to Control Panel, User Accounts and reset the password onthe effected account.
If you cannot perform the above, then this link has the best listing of recovery suggestions I've found:
http://www.tech-faq.com/lost-windows-password.shtml
If you need to change a forgotten BIOS password, you will need to contact Dell Technical Support for a BIOS Master Password.
SOURCE: dell latitude D820 laptop
Put in tye dvd and windows media player should start. If not, then download from microsoft.
SOURCE: Need to replace a broken screen on Dell Latitude D610.
Hi there, please following this show step by step
http://www.geneseo.edu/~stratton/D610_ServManual/azedadis.htm#wp1040875
be carefull :
1) LCD cable pull out/in fromto the panel mark its match.do not force to much
2) carefull inverter cable and lamp wire do not plug in/out too hard.
3) do not touch the new planel top side and left/right side too much, there are sensitive cable inside.
hope help you fix it, send any question at any time please.
SOURCE: latitude d820 screen twitch
call dell and ask them! maybe monitor cable or static electricity!!
SOURCE: SM Bus Controller (for Dell Latitude D820)
open link and download driver .....
driver name chipset .....
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=LATITUDE%20D820&os=WW1&osl=en&catid=&impid=
