Question about Seiko Smart Label Printer Pro Thermal
Change labels for Smart Label Printer 450
How do I open up the Smart Label Printer 450 to change labels? My old Smart Label just opened in the front.
5 Suggested Answers
SOURCE: cd label
I finally figured it out. The default DISC LABEL got set to HP TATTO. It should be PRINTABLE CD/DVD STANDARD. The HP Tatto uses the photo paper tray so the printer wants you to close the DVD tray
Posted on Jun 18, 2008
SOURCE: My printer display keep showing " Warning, Ribbon in", cannot print multiple label at a time
i have the same problem , but my printer is ZEBRA S4M ZPL
my solution is:
in your barcode software: change printer settings: 1 and 2
1 . in media setting : change media type --> Thermal transfer
2. in documents options , configuration --> use printer settings
by Lin Yu Hsien
Posted on Dec 10, 2008
SOURCE: Smart Label Printer 240
Check your labels. Are there black "sensor marks" on the back of each label? That's apparently how the printer lines itself up.
Posted on Apr 02, 2009
ailia
  • 175 Answers
SOURCE: smart label printer will not work in windows 7
I think drivers for windows 7 is under development. Try to install latest updated driver SLP 410 from;
http://www.siibusinessproducts.com/support/slpdiscsoft.html
If not supported, try to install further update from;
http://www.siibusinessproducts.com/support/slpmac_sla.html
Regards;
Hasan
Posted on Nov 05, 2009
  • 5 Answers
SOURCE: OPEN THE FRONT COVER THEN CLEAN THE CORONA WIRE OF
This will solve most "Toner End Life" message problems when you know that there is toner still in the cartridge.
1. Remove the toner assembly by opening the top scanner lid, then pull(tilt) open the front panel, and pull out the toner assembly by gently grabbing the tabs and pull out with an upward motion. The toner cartridge(grey color) and the toner holder assembly (black color) will come out.
2. At the top rear of the assembly you will find a square green tab that can be slide along lengthwise of the toner. Just slide it back and forth fully several (5 to 10 times) times. I carefully blow on it as well(no spitting!) while sliding it.
3. Put the assembly back into the printer, Close the front cover, and drop the scanner cover.
4. Whala ! (usually), actually this has worked everytime for my brother and myself.
Posted on Feb 14, 2010
How do I transfer saved labels from Smart Label Printer 100 to Smart Label Printer 620?
In the SmartLabel directory under Program Files look for a file named label.sll This file holds your SmartLabel 100 addresses. After installing your new SmartLabel printer, copy the label.sll file into the new SmartLabel directory under Program Files. When you open the SmartLabel software, if you don't see your addresses, you may have to use the Import command on the label.sll file to bring your addresses into your new SmartLabel Application
Feb 27, 2015 | Seiko Smart Label Printer 100 Thermal
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
May 08, 2014 | Seiko Smart Label 240 Thermal Printer
After printing a label it advances too far wasting the next label
This is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
Jan 03, 2014 | Seiko Instruments Smart Label 450 Thermal...
Hi there I just got a new computer and try to copy the old smart label printer over, but when I try to print the label out, I got a message says.." SLP print manager can not start" What I...
when you say uyou copied the old printer over I assume you actually reinstalled the Printing Application from scratch?
You cannot just copy the seiko directry over, t doesnt load the .dll files
reinstall the application
biffo
Sep 08, 2011 | Seiko Smart 440 Thermal Label Printer
HAVE A FLASHING ERROR LIGHT. CHECK RIBBON. RIBBON IS NOT USED ON THIS PRINTER. HOW DO I CLEAR THIS UP?
Changing the setting on the printer The default setting is thermal transfer for this printer. You can change the setting on the printer so it doesn't show you the error any more by doing the following: Press SETUP/EXIT Press Plus (+) to scroll through the different parameters About the 6th parameter is "PRINT METHOD" Press "SELECT" to select the parameter Press Plus (+) or Minus (-) to change to Direct Thermal (no ribbon) Press "NEXT/SAVE" to save your changes If you make the changes to you printer and as soon as it prints it reverts back to thermal transfer, then your label software or your driver are overriding it and you need to make the change there.
Changing the setting in your label software - this will also change the settings for this label only Open your label Make the change under "label setup" or "page setup" inside your label software.
Changing the setting on the driver - this will also change the default settings for all future labels that you create Go to control panel and devices and printers. Locate the driver for your label printer and make the change under "Printing Preferences".
Jul 09, 2011 | Zebra 105SL Thermal Label Printer
I've got some problems with my zebra zm400 printer. It says error ribbin out
May 05, 2011 | Zebra 203DPI Printer
We have 13 s4m Zebra printers. We try to change from thermal to direct. Which was no problem during our initial test. But when we try to change actual printer that was being place inside a cooler we kept...
Sep 16, 2010 | Zebra S4M Thermal Label Printer
Smart Label Printer 430
Delete it from Control Panel, unplug the USB cable, then reinstall the softwre.
Jan 05, 2009 | Seiko Instruments Smart Label Printer 430...
Hi, My Smart Label Printer 430 was working fine until I unplugged the back 2 cords to change the tape in it. How do I get it to print again?
unplug your Smart Label Printer (slp430) from your pc,
go into your control panel, then to add/remove programs.
remove the slp430 software then reboot your pc.
DONT PLUG IN YOUR SLP430 yet...
reinstall the software that came with the label printer.
follow on screen instructions.
plug power in for the printer
then attatch to your pc.
if this doesnt work let me know ; )
Seiko Smart Label Printer Pro Thermal Logo
401 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Tralornik
Level 1 Expert
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
