Question about HP Photosmart C7280 Laser Printer
Paper feed jams
Automatic paper feed keeps jamming so I can't fax, scan or make copies of multiple pages. Help please!!! C7280 is All-in-One Inkjet - Mine doesn't seem to want to "grab" on the left side (facing front) Have looked in opened back and see nothing unusual or broken. Paper tray seems to be all the way in, so why this constant tearing and crumbling of the paper I have to grab from around the rollers in the back? It seems to be hitting something on the top as it tries to start to print and continue forward. Help!
  • jamesjrichar Jan 16, 2009
    Exactly same problem and symptoms.
  • cabgal Jan 23, 2009
    While feeling around in the back of the printer after the duplex cartridge was removed, I noticed that I could grab a part at the end of the paper tray with one of my fingers and it would move about 1/4" toward the back of printer. It seemed like that piece had slid forward, out of place, and I put it back where it should have been. The paper was then a little closer to the feeder wheels. After that, the paper fed properly, no more jams. I don't know why I couldn't do the same thing from the front with the tray, but no matter how carefully I shoved the paper tray, it never did move that part that I moved with my finger. Been working for 10 days!!!
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 23, 2009
SOURCE:
Paper does not feed from top of my hp 7210 printer and can not fax from top feeder. I can not use the top feeder to copy multiple documents. Only bottom feeder works. When I have to fax something, I have...
The rollers on the feeder can go bad and the best way to solve it is to get a new complete assembly. Check the website under your make and model for the assembly. YOu might also want to check for paper jam
Mar 19, 2011 | HP Officejet 7210 All-In-One InkJet...
Jammed frequecy
Open the printer panel and check for friction. Better still, contact a service technician near you.
Jun 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Photosmart C7280 Paper Jams
It isn't always about the paper. The video shows a few other things to check.
May 04, 2009 | HP Photosmart C7280 Printer
Feeding paper for scanning/faxing - e-studio350
If u put stack of papers on the feeder, but it didnt pick well or paper jam occur, u need to check the feeder unit. Normally roller is wear and tear, foreign materials inside the feeder and etc will cause paper jam on feeder.
Mar 19, 2009 | Toshiba e-Studio 350 Copier
Need help on lexmark x 4270
To whiom it may concern my printer wont allow me to fax or copy do to it saying paper jam,so I cleared the jam and made sure that nothing is in it but it keep saying paper jam and will not allow me to fax or copy. Can you kindly help me with this problem please.
Oct 28, 2008 | Lexmark X4270 All-In-One InkJet Printer
Paper feed jams
try to clean the rollers of the ADF at the same time the separator pad of the ADF.some the issues why this will encounter jam because of the dirty rollers.but if the issue is occuring you need to SERVICE the product
HP TECH support
Aug 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
Paper jamming in fax
look for a piece of paper in the paper path. clean all paper feed rollers
Jun 11, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
XEROX TELECOPIER 7024
Does it say clear jam immediatly or does it start to run then declare a jam?
If it starts then tells you to clear a jam and no paper is in the machine, your feed rollers are shot. Smooth like trying to drive a car on ice.
If it says that all the time, no attempt to feed then you have a sensor either dirty, knocked out of place or something stuck on a sensor.
Either in the paper path or in the scanner.
Mar 26, 2008 | Office Equipment & Supplies
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
HP Photosmart C7280 Laser Printer Logo
205 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
