I locked my keys in the car and did not know the code
Get a hard plastic wedge shaped device. At top rear of window try to insert tip of wedge, banging on thick end with hand if needed( might need a second pair of hands to help, have them grab and pull out on this area before placing wedge in). Keep inserting it till door is pried open at least 1/2 inch, don't be scared door or window wont break. Get wire style coat hanger straighten it out put a small j shaped hook at the end you insert between weather proofing rubber and go fishing for door lock swicth. Good Luck!!!
Factory Code was on a plastic card when new
To get that ,you need to give a dealer your Vin #
& proof of ownership.
I don't know if you can over ride your code with the
factory code
I have changed codes ,but not tried to enter the factory
one over mine
You vehicle comes with 2 keys & a valet key & you should have
a 3rd key bought & you program it.
What about the remote KeyFOB You should have 2 of those
to open the door
No reason to only have one key
Also the ignition is programmed for 2 keys or
it won't start
