Question about GE GLDA690MWW / GLDA690MBB Built-in Dishwasher
Dishwasher not draining
I run it through the clean cycle and it drains. When ran in the normal wash cycle it does not drain completely. Leaves a few inches of water in the bottom of the machine. I've checked all the drain lines everything is fine. Not having a manual for the machine makes it difficult to troubleshoot it beyond this point. Any help would be appreciated. Either a place to find a manual online for free, or where to start with repairs.
Thanks, Jeff
  • hvacman1976 Jan 08, 2009
    Thank you I will call them right now. I thought it was either the timer or a pump going bad I wasn't sure.
    Thanks
    Sergeant:
    Champion:
  • 262 Answers
Jeff you can call customer service at 1-800-626-2001 and they can help but it sounds like your timer is missing the drain cycle
Posted on Jan 08, 2009
The water is no draining completely out of the dishwasher, its's a Whirlpool 980 Deries
If you are handy what you will have to do is unclog it. DO NOT USE DRAIN CLEANER. Pull out the filters, clean out the **** and you are good to go. Once you are done with that run it a couple of times and you should be good.
Oct 10, 2012 | Whirlpool Dishwashers
The dishwasher does not drain-- it leaves about 1-2" of water in the bottom after running a cycle
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 16, 2011 | Dishwashers
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
Built in dishwasher. Dishes are clean but leaves the interior dirty. Have cleaned it with dishwasher cleaner, then a few weeks later its grubby again.. This has just been happening in the last few...
Check your drain hose to make sure no water from the sink is draining back into the dishwasher.
If it is,re-hook the drain hose up high under the sink.
Next.
Start the dishwasher without dishes or detergent.
Once the fill and was cycle begins,open the door and por in 1 quart of WHITE vinegar and resume the wash cycle to completion.
Mar 19, 2011 | Kenmore 15769 Built-in Dishwasher
Dishwasher is draining during the wash cycle, but leaves water in the bottom at the end of the wash. What could be the problem?
Hello Ellsaesser,
Dishwashers typically leave water in the drain system exitting the pan but not a lot of water. If yours does then make sure you clean the drain screen ( normally located in or around the drain tube exitting the pan of the dishwasher..) If after cleaning that and after a normal wash cycle you continue to have significant volumes of water in the pan, the pump, lines leading to and from that pump may be restricting flow or damaged.. Those are a few of the normal culprets for why there is a lot of water in the pan of dishwashers after a cycle.. Hope that helps you identify the problem and resolve it,..,
Regards
Nov 29, 2009 | Frigidaire Dishwashers
Bosch SHU43C
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Mar 10, 2008 | Bosch SHU9915UC Dishwasher
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
GE GLDA690MWW / GLDA690MBB Built-in Dishwasher Logo
493 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
