Question about Compaq Presario V4000 Notebook
Booting and dvd drive not detected
Two questions: 1.) Usually when I turn on the notebook it breezes right to the windows loading screen and quickly to the sign-in screen. But now when I go to turn on the notebook the COMPAQ startup screen comes up, and it the computer does not boot up. It gives 3 options- Boot from LAN, Enter Setup, and something else that I can't remember. Anyway, I can press the keys to do those specific things, but the computer doesn't boot to the sign-in screen, and, when it gets to the loading windows screen, stays there forever and doesn't do anything. I also occasionally get some type of media error, something like PXE Rom error (I dont know much about computers). I had this problem once before for about two days and I took it in to get it checked out, but the computer booted just fine for the service guy. This time, the problem has persisted for about a week. What is wrong? What should I do? 2.) My DVD/CD drive will not detect either a DVD or a CD. I have uninstalled and reinstalled the driver, but no luck. This has happened occasionally, but it hasn't been a persistent problem until now. What should I do? Thank you guy for your help!
  • 883 Answers
I'm not sure if your pc has a floppy drive, but if it does, then get a win 98 or win ME startup disk then power up and then push the F8 key (or DELETE key) to enter BIOS setup then select boot floppy then and insert into slot then reboot then boot minimal then get to c: drive and run CHKDSK/FIX then try again, w/out floppy. if no-go then repeat back to c: drive and delete the PAGEFILE.SYS file (may need to attribute the file to allow delete) then reboot w/out floppy
Posted on Jun 02, 2007
HOW TO DETECT THE CD ROM USING PHOENIX ROM BIOS PLUS VERSION 1.10 A02
The BIOS information is typically found at or near the top of the POST screen for a very short time ALR PC non / PCI = CTRL+ALT+ESC AMD advanced micro devices=BIOS = DEL Award BIOS = DEL Dtk Datatech Enterprises Co. BIOS = ESC Phoenix BIOS = CTRL+ALT+S Phoenix BIOS = CTRL+ALT+INS Restart your computer during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have Press and hold that key during the boot up process to enter BIOS Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
If the cd rom is not being detected ?
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Feb 28, 2013 | Computers & Internet
Boot up does not load to login prompt. It loops after not detecting D1.D2.D3 and goes right back to the Start Windows Mormal prompt
you will have to change the boot sequence in the BIOS.
preee F2 or Del to enter the BIOS - you can change the sequence, set the first Boot 1 = DVD/CD, boot 2 = Hard drive
press F10 exit and save > ok
next time it will iuse the DVD/CD to boot first.
if you set the boot to b1 = Hard drive & boo 2 = DVD/CD......the hard drive boots
hope this help
merry xmass
Dec 21, 2010 | RaidMax RX-450K 450W ATX12V Power Supply...
My notebook is working very slow. i want to format it. how should i do it?
Well, usually, formatting notebooks and/or computers is the last resort. Try to Defragment your hard disk drives, uninstall unnecessary programs, or upgrading memory to speed your notebook.
To defragment a hard disk drive, do this (For windows 7): 1. Click on the Windows button on the lower left of your screen, then click Computer. 2. A window will open up displaying your local hard disk drives (For example, Local Disk C:) 3. Right click on the disk drive that you want to defragment (Ex. Local disk C:) then click Properties 4. A new window will pop-up, go to Tools tab and under the Defragmentation, click Defragment Now (Defragmenting might take a while depending on the number of files and the size of the hard disk drive. 5. You can do the same steps for the other disk partitions (Local Disk D:, etc)
To uninstall programs (Windows 7) 1. Click Windows button on the lower left of your screen, then click Control Panel 2. A new window will open, look for the Programs part, then click the "Uninstall a program" link. 3. This will take you to the programs list with installed programs in your notebook/computer. 4. Select the programs that you want to remove/uninstall, then click Uninstall.
To upgrade physical memory/RAM (random access memory) 1. Please contact your manufacturer. Memory will be dependent on what kind of notebook model that you have.
If the above suggestions doesn't make your notebook a bit faster, then you might want to backup all your files to another media (like external hard drive, or burn it into DVD's). It would be the right time to format your notebook.
1. You should contact your notebook manufacturer about notebook formatting.
Nov 18, 2010 | Acer Computers & Internet
The power come on but the harddrive will not boot since there is nothing shows on the screen. The screen is blank, no apple sign, no sping gears. pls what do i do,and my mac os that comes with the system...
With regards to the blank screen, this usually indicates an issue with the hard drive being faulty (hardware) or the OS might have corrupt system files (software).
These are the items you will need before we begin:
A. Mac desktop/laptop B. Mac OSX Installation DVD
A. Software Related
1. Power on the Mac computer/laptop and immediately press and hold the option key. 2. After about 15 seconds of holding the option key, release it and insert the Mac OSX DVD. 3. The DVD should load and display on-screen (along with any additional drives available on the system). 4. If the hard drive icon appears, then click on it. (if the hard drive boots the OS, then the issue is software related. Skip down to Section B, step #1). 5. If the hard drive did not appear, then the system does not recognize it. However, the DVD icon should have appeared, click on it. 6. The DVD will boot and begin the installation process. 7. Follow the installation prompts. 8. Once completed, the desktop/laptop will reboot and after logging in, will execute the registration process. 9. Complete the registration exercise and access the desktop. 10. Perform a software update and download all system and application updates to their latest versions.
B. Hardware Related
1. Power on the Mac computer/laptop and immediately press and hold the option key. 2. After about 15 seconds of holding the option key, release it and insert the Mac OSX DVD. 3. The DVD should load and display on-screen (along with any additional drives available on the system). 4. If the hard drive icon appears, then click on it. (if the hard drive boots the OS, then the issue is software related. Restart the computer and skip up to Section A, step #1). 5. If the hard drive did not appear, then the system does not recognize it. However, the DVD icon should have appeared, click on it. 6. The DVD will boot and begin the installation process. 7. Close the installation application and select "Disk Utility" from the "Utilities" menu option. 8. When Disk Utility loads, look to the left-hand pane and locate your hard drive (if detected). If so, click on it and format the hard drive then reboot and skip up to Section A, step #1. If the hard drive is not detected, then the hard drive has malfunctioned and needs to be replaced.
Hard drive's cost from $40-100 for sizes ranging from 40GB to 1TB. Once the hard drive has been replaced, you can install OSX from the installation DVD.
Aug 11, 2010 | Apple PowerBook G4 Mac Notebook
I have a blue screen with no text at boot, it shows only after i do bios fingerprint check, in order to get acces to windows 7 i have to turn on and off couple of times, i do cd dvd boot, hdd and fdd boot...
Basically some causes of blue screen is the RAM check the RAM remove first maybe it is clogged by the dust. Remove the dust of the memory stick and insert it back to you computer. Usually of you have this problem again you need a recovery disk. Load a windows CD to your CD drive you need to boot and repair the windows.
Dec 10, 2009 | Toshiba Qosmio F45-AV412 Notebook
Cant get on.keeps saying operating system not found.ihave windows xp.can you tell me what to do and why its doing that?Thanks
Do you have the original start up disc? If so use it. If not there is generally a button to use at start up that will get you to a screen where you can restore your computer to a previous date. The button is usually F10 or F11 or one of the f keys. Also make sure that you don't have a disk in one of the drives. Take everything out and try starting it up. Good luck.
Jul 30, 2009 | Compaq Presario 700 470024-192 Notebook
Brand new notebook .. windows then, screen freeze..acer picture
This may require a "repair" of windows.
Get a Windows XP Operating system disk with the correct service pack that the notebook has installed (usually XP SP2).
1. Boot from it (put it in CD drive and restart the laptop).
2. If you still get the same problem start up, you need to set the laptop to boot from CD.
3. Restart laptop, press Delete key or F2, or F12 (it should say one of these on the screen) to enter the Setup. or another key to get "boot options"
4. In Setup (BIOS) Use Right Arrow to find the Boot Options. Use the instructions to move the CD-ROM to first position, above HDD (hard drive). Press Esc, then F10 to save your changes and exit.
5. The XP CD Rom should now run. It should come to a screen where you are asked to press R to repair windows.
6. When it comes to the command prompt, restart the laptop
Hopefully the laptop should boot OK again.
Jan 25, 2009 | Acer Aspire One PC Notebook
I have to turn it on twice! It turns on normally and just when its about to load windows the screen goes black, then I have to turn it off and on again for it to load windows.
You can choose go to advanced startup menu by using F8 during startup and choose "Last Know Good Configuration"
about DVD playback; right click on your DVD drive (Usually D drive) on properties go to Recording tab and check the box highlighted below.
Good Luck
Jan 21, 2008 | Dell Latitude D600 Notebook
Blank screen
right mouse click on the desktop now show the desktop icons? was this ok?
Sep 18, 2007 | Dell Inspiron 6000 Notebook
Compaq Presario V4000 Notebook Logo
108 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
