Board cracked on red crt for toshiba 42h82
Hi
i was taking apart a toshiba 42h82 to part out and i put the crt in a box and when i moved the box i hit the wall and cracked the board on the complete red crt assembly...its a small board that is on the end of glass neck of the crt assembly.....
my question is that is this board repalceable or does this mean the entire red crt tube is trash........can i still part out the red crt in any way without the board
  • dcxguy48080 Jan 09, 2009
    thank you i dont want to repair it i jsut wanted to know if the crt was still ok........i am going to try to sell it without that board
    do you know how it comes off.......man the crt assembly is so much involved......whoever comes up with these ideas is just incredible......
    i appreciate your help i love this site
    also other than service manuals where can i find the resistor values and pico values for all proj tvs involving convergence.....i have been doing convergence jobs on the side since im laid off work...its good money and not hard work.......
    thank you very much i will try sometime soon.....
  • 505 Answers
The board is a seperate part and can be replaced. look at the bottom of it and see how many wires were broken in the crack.. it may be able to be repaired as well
Posted on Jan 08, 2009
  • thielectronick
    thielectronick Jan 09, 2009
    Yeah its easy as long as you don't have to do much realignment.. as far as the resistors and pico fuses, they should be labeled. the fuses are usually like a small black resistor in toshiba, in others like yellow or green resistor. It will say like 5a for 5amps or maybe 5000 on the yellow/green type. Convergence resistors harder to tell if they're burnt up, but you can usually take the simmilar ones around there to find your answer. There is 1 feeback and 1 input resistor for each amp, so 6 inputs and 6 feedbacks. In inputs almost always burn up.. like 1.8ohm up to 3.9ohm. The feedbacks will be like 100 x the value.. so 180ohm or whatever. Sometimes they'll use a pair of resistors instead of just 1, like Mitsubishi will put two 3.9ohms in parallel for the inputs.
    Back to the crt, be very careful not to open the seal and let out the cooling fluid! This is the biggest part to worry about, that and cracking the glass. On a PTV the tube will discharge, but not in smaller crt tvs. Anyways, unscrew the holder on the board and carefully pull it down the neck of the tube.. slightly jiggle, dont rotate! you can do the same to get the yoke off.. then on the top side 4 screws hold it in. You've also got to pull the anode from the splitter and ground wires, etc.. you can usually remove the lens from the top but be careful not to take the wrong screws or the toxic cooling fluid will leak out. Let me know where you need help. Thanks
What does the hyperboard look like
The actual board is in a box, careful the four metal pins must be un-soldered to remove the unit from the main board.
Nov 30, 2012 | Toshiba 42H82 42" Rear Projection...
Toshiba 42H82 the screen will go black after 5 minutes, sometimes it comes back on after a minute, but most of the time I have to turn it off for about 10-20 minutes. Some days it works fine, others it...
Hi.
It is probably a defective ballast board or a faulty PSU. The ballast is the high voltage power board connected to the lamp.The PSU is the board that supplies power in different voltages to the other internal parts. One of the DC lines from PSU goes straight to the ballast. The repair is done testing the voltage from PSU to ballast. The job must be done by a technician.
Dec 15, 2011 | Toshiba 42H82 42" Rear Projection...
Toshiba cf32h40 started last week the pic would go down to one thin line i would hit it on the side and it would come back ,but now thin line comes back when i hit and then goes away so i took off the back...
that silver box is called TV tuner (see picture ) ............ but in your case that is not the problem ......... after 4 or 5 yrs (depending on usuage ) in some TVs on mainboard & CRT tube's circuit board at some soldering joints cracks develops ... then due to loose contact TV behaves as you have described ........ when you are hitting that lightly on its side then these cracks at soldering joints are getting connected temporarly & for few seconds or minutes you are getting normal picture ....... so solution is most of the soldering joints on mainboard & on CRT circuit board has to be resoldered ....... only good tv service engineer can do this without shorting joints or damaging components..... so that silver box ( TV tuner ) is not the problem because when it gets deffective then you will get picture that comes when tv is switched on ---- usually it will be blue screen ......& also if you connect dvd you will get picture normally ...only thing is that you won't get picture from cable or antenna .............. vishnuswamy_25.jpg
Sep 01, 2011 | Toshiba CF32H40 32" TV
My 42H82 picture works but fuzzy...Letters in menu are clear though..need help
hi,
ur tvs crt sockets have some problem. change the three crt sockets at the same time . also check for screen voltages of crt's. increase it slightly. there will be three independent screen voltage adjustments for each gun.
ok
Dec 23, 2010 | Toshiba 42H82 42" Rear Projection...
When I run the Touch Focus , it ends Touch Focus Error, and the Red Verticle line does not move , the Horizontal is bent .. now tv is fuzzy?
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 27, 2009 | Toshiba 42H82 42" Rear Projection...
Toshiba 42h82 - "broken" picture
the "scan converter module" is located directly behind the board where your inputs are in the back of the set. That should repair the problem.
Jan 08, 2009 | Toshiba 42H82 42" Rear Projection...
Toshiba 42h82 convergence resistor and pico locations
yes better.  you need schmatic. servicemanuals.net.
Dec 13, 2008 | Toshiba 42H81 42" Rear Projection...
Red color abunDANT
Please verify model # from rear of set.PVAT! Look closely at signal PCB for signs of CRT coolant leak.
Oct 03, 2007 | Toshiba 42H82 42" Rear Projection...
Toshiba 42h82 no sound
Are you using a Cable Box?Using HDMI? Need more Info........
Jul 19, 2007 | Toshiba 42H82 42" Rear Projection...
42H82 Picture is ALL GREEN
If the picture is all green and does not shutdown then is probably not the tube and you need to check the green output transistor witch is ussually located in the crt board in the neck of the green tube,you also have an IC that gives the colors then you have a driver and finally the output,(IC and driver rarely go bad but is possible),when you pull the board out of the tube make sure it comes out easy,do not twist the board because it might brake the pins in the tube(gun) and then we will have big problems, many times they secure the board to the tube with silicone and it needs to be removed or cut before the board will come out.Each gun has an output and the defective one should be replaced with an exact replacement.Check also the conections in the green crt board.Let us know if you need more information.
Oct 26, 2006 | Toshiba 42H82 42" Rear Projection...
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Electro Med Services...
