Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
How do I install a password on my Belkin N router
I changed the nickname for the network but the securuty icon on the router is not lit up blue. How do I put a password on the network
  • Bohann Mar 19, 2009
    anyone is able to connect to my network i want to password it so people cant access the network without that pass
    Problem Solver:
  • 6 Answers
I missed my passfrath on wirred
Posted on Mar 10, 2009
Changed password now can"t access router
Your laptop still insists on using the old password that's why it can't connect. Go to Control Panel > Network and Internet > Network and Sharing Center > Manage Wireless Networks. Select your router's SSID. Right click on it and change Properties > Security > Show characters. The old password that you forgot should appear. You may then change it to the latest one.
You may also click on the wifi signal icon on the lower right corner of your Taskbar, right click on the router's SSID, select Properties > Security > Show characters to reveal the old password you forgot and change it to the latest one.
Jan 03, 2013 | Belkin Basic Wireless Router
Hi, I'm using a Belkin N1 wireless router. I mostly have a stable internet connection, but once in a while the "wireless" icon start blinking orange. What is this? My internet some times get...
if the wireless light is lit up in red it says "someone is trying to connect to your network using wrong password"
Sometimes if any of your devices are not compatible with the security enabled in the router then the light will lit up in red. click here to know more about security types of belkin router
routers has to be turned off atleast 2 hours per day for it to work properly... so better turn off the router when not in use, this will clear the routing table of your router and will make the router to work as a fresh router everyday, so you wont face any speed problems.
May 03, 2011 | Belkin N1 Wireless-N Wireless Router
How to connect my laptop wirelessly to the belkin router?
You may want to click to wireless network icon on the bottom part on the rght part of your monitor and search for network. Then you may want to chose your network and, if you chosed this option, to type the password for the network.
Let me know if you were successful in solving your problem
Mar 01, 2011 | Belkin Computers & Internet
I have installed, set up, and created my router's name, password, and key, but im still having trouble connecting to the internet. The little icon that looks like the earth is glowing orange, and the only...
Use the network setup wizard to connect to your network, and the internet. Unless you did this already.
You can get the wizard from Control Panel, Network ... , Connect to a Network. If wired you won't need key, it's for wireless only.
Yo did not say what OS, so info is a little generic.
Hope this helps.
Jan 26, 2011 | D-Link DIR-615 Wireless Router
How do I erase my password for Belkin f6d42301-4 wireless
In control panel find the network icon, click on this to show the router icon, RIGHT mouse click on this and "view device webpage", this should enable you to access the security settings and you can set the password for the wireless by deleting it first (change to no wep no wpa) and then re-enabling it
You can also change the router password
Dec 29, 2010 | Computers & Internet
I just bought a belkin wireless modem router (F7D1401). I have installed the belkin router monitor software in my laptop which running on Window XP. After installing the software, there is no window pop up...
Hello
It shows that the software does not installed properly, or you might select diffrent OS during installation, re-installation with proper inputs is recommended,
Good luck, do rate the solution if got help
Dec 08, 2010 | Belkin Basic Wireless Router
My computer will not connect to my belkin router...it says that it is securuty enabled but I did not set that up. How do I start all over again
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Oct 27, 2010 | Belkin (F5D7230-4) Router (587009)
My laptop was working fine with my belkin wireless router..next second nothing..all lights lit execept the one that says wireless..the little blue light on the computer is lit..any suggestions??
I believe the wireless setting on the router are default .You need to make it manual and change the channel to either 1,6,9 or 11.....and upgrade the firmware of router ...and if available make the radio band to standard 20 mhz only or 20 mhz only whichever be there under wireless settings,,,Problem will sort out
Dec 30, 2009 | Belkin (F5D7230-4) Router (587009)
Dsl modem network cable attached modem icon
Are you trying to set up the router ?
First make sure that your computer is online when connected directly to the mdoem. ISP is DSL.
If not online through the modem then you should have user name and password for the ISP.
try to reconfigure the router.
Click Here for more info about router set up.
Nov 19, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
199 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
