When I put my vehicle in drive it jerks a little and when I start to drive and as the gears are about to change it will make a loud bang and jerk abruptly, also when I start to slow down, the car will make the same noise and jerk abruptly. Is this an easy fix or require the transmission to be replaced? PLZ any suggestions. Thank you
Several things could be causing your problem:
Hope you find that this answers your question. Best of luck.
Greg
p.s. If you have the fluid changed, make sure it's done from the tranmission pan, not through the filler tube; siphoning through the filler tube can be hazardous to the transmission, especially cars with a lot of miles
SOURCE: won't go into gear to drive. may be transmission?
If the clutch has never been changed most likely it is that. The way you can check it is by removing the transmission and looking at the clutch disc. It could be transmission syncros but I am willing to bet you just need a new clutch.
SOURCE: Front differential making a winding noise and ends in a loud thump.
sounds like you need your transfer case looked at and repaired.....that the only thing i can think of...hope it helps :)
SOURCE: 1999 Olsmobile Alero
sounds like bad clutches in trans...tranny shop needed...takes 4 qts for a filter change and remember to check it when the vehicle is warm and in park running.
SOURCE: 2000 ISUZU TROOPER WITH AUTO TRANSMISSION. CHECK
If the fluid is up -
it could be a vacume loss or the shifting module..
The shifting module is what tells it to shift - and it is controled by vacume pressure..
Hello
The
Engine and Automatic Transmission (not applicable to manual
transmissions) in this vehicles drive train are fully
electronically controlled by a computer called the PCM and TCM (Power
Train Control Module, Transmission Control Module). When a problem
like this or other drive-ability related problems occurs the computer
stores a record of the problem (there are of course some exceptions
to this, like the fuel pump, engine coolant temperature sensor and
MAF sensor for instance) in the form of a fault code in its memory,
to read these fault codes you must have the systems memory scanned
with a special tool. Once the fault code(s) are read you then must
perform the appropriate diagnostic testing to find and resolve the
problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED
TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD
EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM. Also always
check fuel pressure for correct spec for your make and engine type.
