Question about ASUS SiS Chipset CUSI-M Motherboard
Processor upgrade I have an old pentium 3 400mhz pc with an asus cusi m 533 motherboard.i would like to know if i could still upgrade my processor.Im planning to add a dvd writer and a video capture card to it so i can convert my video 8 tapes to dvd.However,the technician said a dvd writer needs at least 700 mhz.If the processor is upgradable,what processor would be compatible with my motherboard?
  • Anonymous Dec 06, 2007
    hi
    I have a asus sis chipset cusi-m motherbord and i went sound ang display driver for it. please help me to find the drivers.
    mesrabadi2@yahoo.com
  • 883 Answers
Boot it up to BIOS screen now and look at CPU settings. It may tell you the maximum speed.
Posted on Jun 02, 2007
45CMX/45GMX/45CMX-K I do not know what video cards and processors are compatible with this motherboard as I want to upgrade my pc
Hello download the manual here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000341
Intel Core 2 Duo, Pentium Dual-Core, Pentium D, Pentium 4, Celeron D, Celeron processors, Socket T (LGA775)
- 1333(oc*)/1066/800/533 MHz (FSB)
- Dual Channel DDR2 667/533/400 x 2 DIMMs, Max. 4GB
- 1 x PCIe x16, 1 x PCIe x1, 2 x PCI
- ATA x 1, SATA II x 4
- 5.1 channel Audio
- 10/100M LAN
- 8 USB 2.0 ports
Good luck
Jun 17, 2012 | Foxconn 45CMX socket LGA775 motherboard...
I have an old desktop pc, ASUS P4S533MX, Intel socket 478, with SiS PCI IDE Controller.. ( IDE ATA/ATAPI ) 1. Can I upgrade the Radeon 9250, 128 Mb DDR 64-bit to something better? 2. Is it...
well...ASUS P4S533MX- Intel socket 478 allow maximum processor upgrade from 3.2 GHz upto to 4.2 GHz.
for upgrade the Radeon 9250, 128 Mb DDR 64-bit ....whole moherboard along with new processor has to be replaced. an expensive deal..
better to buy new motherboard+compatible processor of ur choicce
Sep 19, 2010 | Intel ASUS P4SC Socket 478 Pentium 4...
ASUS CUSI-M ACPI BIOS Revision 1007 run very slow when i wana use 1024 by 768 pixel.how i can solve this problem.my processor speed is 700 MHz. 2.is it possible AMD 1.3 processor connect with this...
Getting you're system to display 1024 x 768 resolution depends on the graphics card. If you’re using the onboard VGA you will have poor display.
Suggest you use a PCI (White slot) graphics card with its own memory onboard. You will also need to make a bios setting change so the system boots to the PCI card and not the VGA.
Asus no longer provides support for this MB including drivers and bios.
You're board also supports slot A (For AMD), processors.
Only Intel Celeron and Intel Pentium III. Socket 370
see link provided;
http://www.cpu-upgrade.com/mb-ASUS/CUSI-M.html
Max CPU supported (With out over clocking);
http://www.cpu-world.com/CPUs/Celeron/Intel-Celeron%201100%20-%20RB80526RY005128%20(BX80526F1100128).html
In order to run this CPU you would need to update the bios to rev 1009. You'll find rev 1009 at the next link; http://www.userdrivers.com/BIOS/Asus-CUSI-M-BIOS-1009-With-LAN/
From what I've read it is possible to Get an AMD slot A CPU into a socket 370 MB. (Don't hold me to this though. This is a first for an old dog.
Any one of these PCI graphics cards should function on you're MB; http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=28&sel=Detail;55_158_2872_2872
Hope you find this helpful
Mike
Jun 04, 2010 | ASUS SiS Chipset CUSI-FX Motherboard
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
I have p4 3.06 ghz processor on mother board it is written P5P800-vm/s i require VGA and sound drivers(realtek ac97 sound driver} i have i P5P800 VM motherboard and i was wondering if i can upgrade it's...
NO. you cannot install DUO to *********** board. the DUO is pinless and the P4 3.06 is pin type if you want to upgrade your PC you have to replace the mother board too.
May 18, 2009 | ASUS P5P800-VM Motherboard
Old computer ram upgrade without manual
564 mhz means it is a Pentium 3 or equivalent. This also means that the motherboard does not support DDR2 RAM which is exclusively for Socket 775 and Pentium 4 chipsets. Pentium 3 usually support SD-RAM, also but very rarely DDR1 RAM. Sorry but DDR2 will not work in your PC.
Mar 02, 2009 | Intel Motherboard
I have an asus p48vx-x motherboard
you may check
1) your Intel pentium 4 3.2 GHZ cpu socket 478 processor #sl7nb what's FSB?( see on the chip surface, if 533 FSB can use but 800FSB could not match your motherboard if which is not support 800 FSB. that's why no display.
2) check RAM stick speed, try to increase a level, for example 266 to 333.
is this helpful please feedback thanks
Feb 12, 2009 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
How to place an Celeron processor on ASUS P2L97 motherboard
You cannot use an Intel Celeron processor on this motherboard. the motherboard you have is a slot 1 pentium 2 board whilst the celeron uses socket 478 pentium 4 processor platforms
Jan 03, 2009 | ASUS Intel 440LX Chipset P2L97-DS...
Drivers
I have lost my motherboard driver cd.how I can get the sound driver software.motherboard companyname:asus
model:cusi-fx
revision:1009
version:V1.0A
Jul 23, 2008 | ASUS SiS Chipset CUSI-FX Motherboard
Regarding upgradation of SDRAM
hi dear
there is always speed mismatch problem occur when we use low processor & high ram
so try to use 256 ram
also try to use 1 slot of 256 ram & 2 slots of 128 ram diffrently
& compare the speed
hope it will help to u
Jul 08, 2008 | ASUS SiS Chipset CUSI-FX Motherboard
ASUS SiS Chipset CUSI-M Motherboard Logo
121 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
