Question about Whirlpool Duet GHW9150P Front Load Washer
Drain I have an intermittent problem with my Duet washing machine. I put a load to wash the cycle completes and when I open the door my laundry room is flooded with water. The last drain and spin cycles apparently do not complete however the display shows the load is complete. I have already had to replace the flooring in my laundry room and closet and would like to avoid the mess and expense. Any advice would greatly be appreciated. Kathy Travels.
  • 1 more comment
  • pjmassey Jan 09, 2009
    I found water in my washer the other day and my towels are starting to smell musty. They are new towels. My sons' clothes are not getting clean -- have to wash twice to get deod smells out of them. Wish I never bought the dang machine.
  • kathy641 Jan 09, 2009
    Thanks onthejob5130!!! I removed the filter as you suggested and found .61 cents, paper, and lint build up. I cleaned the filter and started a new load with no problems. Thanks again.
  • Anonymous Mar 31, 2014
    and will fill up within 24 hours and when you open tne door water will flood the floor in the laundry room
During wash cycle FO2 code. o whirlpool duet washer . Cancel X2, unplug washer as per troubleshootg chart . Put o dra and rinse cycle eventually FO2 code again
Posted on Jan 10, 2009
  • 640 Answers
Kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Posted on Jan 09, 2009
  • onthethejob1
    onthethejob1 Jan 09, 2009
    cool ,,onthejob,also when you get time give it a bleach flush,,,hot wash cold rinse with about a pint of bleach
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I getting a funky smell in my laundry room and bathroom, but only when I am doing laundry. I am wondering if it has something to do with the hose. Its be like this for about six months.Thanks
It probally mildew growing inside the wash tub and associated water connnections like the pump housing, drain hoses. Mildew growth is common problem with front load washers. You can try to reduce the occurance of mildew by leaving the door and soap dispenser door open when not in use. Also wipe with door gasket with a rag to dry it.
To kill the mildew in the machine wash an empty load with hot water and vineagar about once a month. Repeat as neccessary. There other products to help reduce mildew such as affresh. Hope this helps you.
Aug 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Laundry room smells like rotten eggs
Does the sewer drain line have a trap at the bottom that prevents sewer gas from entering the room? If the smell seems to be coming from the washer itself, run a wash cycle empty with a cup of baking soda, detergent and hot water to clean the interior.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Samsung Front Load washer has odour
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Sep 01, 2009 | Samsung WF203ANW Front Load Washer
My GE washing machine smells of meldew, I don't see water in it but when I shake the machine i can hear the water sitting at the bottom. How do i drain this water and also how do i get to it?
Jun 05, 2009 | Indesit W 123 Front Load Washer
Laundry stinks
I find that the dryer does not dry the clothes enough. The washer can take a lot of laundry at one time but the dryer is not able to handle the load. The stink usually comes from a bit of moisture left in the the clothes, especially the towels. Break down your dryer loads or dry them on a timed cycle for a longer time.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water inflow even after the cycle is complete
Seems to me that you having problem with water valve in this machine. Some solenoid on water valve is stock and water entering the washer even power is off.Water valve Part # 8181694.
Valve located on the top of the washer. Any questions let me know.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door wont open
did you try running a drain and spin cylce? there might be water in machine still and thats why door not unlocking..Assuming theres no water in machine( youcant see any waterline though glass) you can remove the bottom cover (3 torx 15 screws) UNPLUG UNIT. reach your hand up approx six in. on right inside face of unityoull find a manual release for the door lock assy, round tab mounted to bottom of latch assy approx size of a quarter, give it a pull and door will open,might be a fluke that it lock but i would check for operation before filling with close again
Feb 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
376 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
