Question about Frigidaire Dryers
Dryer not heating
My Frigidaire Gallery front loading dryer does not produce heat any more. It is model number FSG747GES1, purchased in 1998.
  • lasfloresdri Jan 08, 2009
    Thank you so much...does this also apply to a gas dryer, like mine?
    Master:
  • 623 Answers
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Posted on Jan 08, 2009
Replace bearing in a GE SXH47eg1WW dryer
The bearing is the plastic which holds the front glides. It just snaps in place and is easy to remove using flat blade screw driver. The bearing has 3 or four glides which are purchased separately. The rear of the dryer also has a bearing which is plastic part number WE3x75 on the old models, newer models use a different number.
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gib
Apr 14, 2014 | GE Dryers
I have a Frigidaire Gallery W/D set. The model number for the washer is GLWS1339CS1. I need to dryer model # and the sticker is missing. Help?
Hi Joshua, I am happy to assist you!
I understand you are seeking the model number of your Frigidaire dryer because you are in need of the replacement part number of the heating element. Each appliance has its own model number listed in the serial tag on the unit itself. If the serial tag is missing or no longer visible on the upper front as you open the door of your dryer, at this point I would recommend reaching out to the manufacturer to verify if they have any documentation or your product registration. Best regards - Z
Mar 28, 2014 | Frigidaire Washing Machines
Makes a ticking or clicking noise when dryer is on. How can I fix it? The heat and tumbler still works though.
Hi Lisa, thank you for your post!
Based on the above-listed model number, FEX831CS it shows you have a Frigidaire laundry center. However, you mentioned that it is a gallery series. So do you have a laundry center or a Frigidaire gallery dryer? In order to better address the issue, what is your model number? You can typically locate the serial tag, which lists your model number, on the right or left edge on the inside of the door. How often do you hear the ticking or clicking noise? With this information I can better assist you. Thank you!
Dec 12, 2013 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire gas dryer, gallery series model GLGQ2152ESO - no heat,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
My Frigidaire gas dryer isn't hot. Otherwise it runs fine.
it could be either your ignitor(glow coil) flame sensor control, or a defective thermal switch telling dryer its at temp and shutting off gas supply before it even fires initially
Oct 17, 2009 | Dryers
Frigidaire Gallery Dryer Needs Two Cycles to Dry Clothes
A dryer needs to exhaust properly in order to dry no matter where it's situated. Insure that the venting is not crushed at the back and that it has a good strong air flow outside
Jun 21, 2009 | Dryers
Dryer wont stop. Keeps spinning and heating
repairclinic.com is a great site to buy parts from.
May 16, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
My Frigidaire Gallery front loading dryer does not produce heat any more. It is model number FSG747GES1 and was purchased in March 1998. I don't know if it needs a new heating element or a vent cleaning.
Check to make sure you have 220V. Make sure you have no blockage of air flow (lit glogged up). Unplug dryer, Check your thermostats. If they are good check your heating element and take it out and visually inspect it.
Jan 08, 2009 | Dryers
Dryers Logo
363 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
