Who installed the engine? If you did, check all the Grounds/Earths under the hood/bonnet. If the mechanic/shop did, take it back and have them fix it.
Td
Yeah the garage have has it back twice but it still keeps happening so thought I'd ask on here before it goes back in the garage incase it was a simple problem that I could have fixed. Thanks for the reply bud.
Is this an aftermarket audio system with an amplifier? If so, they may have forgotten/missed/broken the lead that may run directly to the battery, which is how some upgraded systems are wired. TD
No buddy it is the standard audio system in the car, everything is standard about the car, hasn't been messed with.
SOURCE: 1994 toyota corolla blowing AM2 30A fuse under the hood
On top of the cover of the fuses it will tell you what that fuse was for. Odds are whatever it is, is shorting out and will need to be replaced.
SOURCE: I have a 2002 Ford F150. Fuse 15 (5 Amp) keeps blowing.
replace nuetral safty switch for gear shifter and check window relays
SOURCE: Keeps blowing starter fuse when you turn the key to start engine.
YOU GOT A IGNITION WIRE TO STARTER SHORTING TO GROUND.
SOURCE: my 2002 dodge stratus keeps
hello, did you figure out why this fuse kept blowing? mine is doing the same thing. no clue why
SOURCE: My 15 amp dome fuse keeps blowing. Car is a toyota
Remove the battery from the car and charge it up first and then re install it.Some newer vehicles will disable the fuel pump if the battery voltage is low,even if it is jump started ,as it activates the anti theft system.
