Cannot turn on tv
After a power outage,tv would not turn on.All I get is a blinking green led that says timer I tried pressing the rest button and pulled the plug for a minute to no avail.I might add that the tv was plugged into a surge protector.Its a 58" Mitsubishi rear projection set about 8 years old
  • 2,920 Answers
It sounds like the power surge got past the surge protector and damaged one of the boards in the back of the tv. it may or may not be worth fixing depending on what you want to spend on it
Posted on Jan 08, 2009
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
3 Reset System
From the remote, press
<MENU> <1-2-3>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
All customer settings are
reset to factory default.
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Green light flikering
Replace all 7 capacitors in the DM Module on the DM Power Supply Board. If it is similar to the WS-65869 and WS-65513 it will have a metal enclosed DM Module at far left of chassis, looking from rear. About 4 or 5 connectors, screws, and Module slides out. Take top shield off. Take good notes or use digital camera or video recorder to make re-assembly easy. These capacitors are 1000uf@16 volts. They always check good, just replace them! After re-assembly plug AC in and wait 90 seconds or more (green Timer LED will stop blinking), then press Power button. If Timer LED doesn't stop, look for small pinhole (System Reset) and press switch with pen or small screwdriver, then wait for green LED to stop blinking. Then Power On TV.
Feb 08, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Error 5100 canon ip90
You may try this to rest the 5100 error:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Dec 07, 2008 | Canon PIXMA iP90 InkJet Printer
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Televison & Video Logo
205 people viewed this question
Top Televison & Video Experts
