Question about Lavazza Espresso Point Capsule Machine
Coffee not dripping out of the machine
The machine is filled w/water..when
I put the capsules in..machine makes the same sound but no coffee
drips out...
  • 1 more comment
  • franl1016 Jan 09, 2009
    Thank you...but now what do I do...Do I need to send it for
    repair??
    Where do I go to fix it??
    Fran
    repair??
    Fran
    repair??
    Fran
  • 69 Answers
Let it run without coffe tablets, if no water comes out probably the conducts are obstructed, may be calcium in the pipes...do water come out somewere else?...
Posted on Jan 08, 2009
  • Stefano Andreani
    Stefano Andreani Jan 09, 2009
    let the machine run with water and salt (two spoons) if there still problem then u can buy a calcium polisher (the same u use for cleaning yr rubinets for instant) check if water comes out somewerelse...if water goes in the electrical circuit can be dangerous! try to clean the filter in the way that u see trought the little holes, maybe it is occlused.
Why does my mr. Coffee decanter leak?
First I'm not a Mr. Coffee tech but I have worked on similar machines.
* Most decanters are made of tempered glass and unless cracked it should not leak.
* Most overflowing pots are caused by over filling brewing tank. This can be caused by re-pouring additional water into the brew tank. (automatic brewers may have a leaking water valve - call your vendor for service)
* Partial brewing (taking coffee from a brewing pot) and then putting in more water.
* Removing the pot BEFORE it stops dripping. It leaves a puddle of coffee on the warmer plate
*Over filling the water tank. Most times the extra water will spill out the back. But some may overflow into the basket area then the warmer plate.
* Follow the MFR brewing instructions for filling.
* All brewers should stop water drips after brewing. If you get a constant drip AFTER brewing then have the brewer checked or replaced. Call your vendor.
Aloha, ukeboy57
Jan 15, 2018 | Mr. Coffee Coffee Makers & Espresso...
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Delonghi Nespresso Coffee Machine Model EN66 After years of great use our machine now has small drips from the main coffee/water spout after use.
Try running apple cider vinegar through it. A few times. This is a mild acid that will get rid of mineral deposits from water. I do this on my coffee maker. Run straight water a few times after to get rid of the vinegar taste.
Dec 10, 2016 | Cars & Trucks
Notice deformation of the capsules ,water also leak to the tray
is it everytime little coffee,or sometimes?
If is everytime -you have to descale the machine,if just sometimes you have to cllean flowmeter,wich is on the back of machine.
May 01, 2015 | Lavazza Espresso Point Capsule Machine
My Nespresso Xn250140 U doesn't work. Why?
Check the hole where you put the capsule, are there any faults or obstructions visible? If not be very suspicious of your capsules, there are lots of brands of Nespresso coffeemakers and the capsules have slight variations between the different brands. The variations are almost invisible but enough to prevent the wrong capsules being used.
Jan 28, 2014 | Krups Nespresso Xn250140 U Coffee Machine,...
Nespresso U coffee does not come through the spout
There are two nozzles in front of the machine attached together, the nose of the bigger one on the top slides into the smaller one on the bottom. When it makes coffee, the spout outside the machine becomes lower so coffee can come out. When it is done making coffee, the spout goes up so water/coffee drips in the drip tray. If one of the nozzles breaks, the spout on the smaller one will not go down and the inside end is lower and coffee goes inside the drip tray. It has nothing to do with cleaning.
Jan 20, 2014 | Nespresso Coffee Makers & Espresso...
I have a saeco magic deluxe that had water dripping into the dredge drawer after making coffee. I also had clear water under the machine on the countertop and excessive dirty water in the drip tray from...
Hi
Sounds like your drain is getting plugged with coffee residue. Remove your brew unit. There is an injector that has 2 orange o-rings in it in the back. That pocket below it is filling with water. There is a drain that is to the bottom left that goes into the drip tray in front. Use a prob of some kind that is about 12" long that you can stick down and forward in the drain pocket. Work it towards the fron and you should open the drain again. it fills with oils, so use some hot sudzy water and clean it out.
Dec 13, 2010 | Saeco Magic De Luxe Espresso Machine
Coffee starts dripping down before I can get the water all poured in and the pot on the warmer, causing a mess.
This is common with bunn coffee makers, if you are not fast enough, coffee starts dripping. The only solution I found is to use a water pitcher, first fill coffee pot to cup mark you are using, then pour into pitcher, put pot back on machine, then pour in water. You can mark a line on picture, so you know where to fill to each time.
Jul 15, 2010 | Bunn NHB Coffee Maker
Lavazza Espresso Point Capsule Machine Logo
776 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
