Question about Frigidaire GLTF2940ES Front Load Washer
Dimensions of current Frigedaire front load washer
I currently own a Frigedaire FWTB69RGSO front load washer that I stack with the similar dryer. I need to replace it and plan on purchasing the FTF530F. Will this new Frigedaire washer work for stacking purposes? thanks
  • Anonymous Jan 13, 2009
    I need a new washer to replace the Frigidaire GSTF1670AS0 to go onto of my current dryer. What fits?
5 Suggested Answers
SOURCE: directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Posted on Nov 16, 2007
SOURCE: Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Posted on Dec 26, 2007
geemarie
  • 876 Answers
SOURCE: need new washer to stack on my dryer!
measure your dryer carefully and check with the dealer where you wish to purchase a machine, regarding
the stacking kit. It may work. They are general standard sized. Don't ry to gerry rig anything or you may have big problems. In your case I recommend using a well known SMALL appliance store that does theri own installations, so they will bring what they may need, but if yours works, they can still use it.Good Luck
Posted on Aug 13, 2008
SOURCE: pressure switch on stack washer
Make sure that not more that 6 inches of the drain hose is in the drain pipe. Too much hose causes a syphoning effect. Water goes into machine and then syphons out into drain.
Posted on Sep 04, 2008
onthejob5130
  • 640 Answers
SOURCE: Stacking dryer
the 2 plastic pieces 1 goes on front 1 on back,,place the one that has open for dryer legs on back,,,and the one in front does not have openings you must pick up dryer to get font on ,,slide back first than pick up front
Posted on Jan 03, 2009
How to open front panel
There were two (2) small screws at the very bottom of the front.
  • Remove them securing the dryer front access panel to the dryer cabinet.
  • Lift the panel until the tabs can be disengaged from the cabinet.
  • Remove the panel and set aside.
Installation Manual (see page 8)
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/131661700p1-8.pdf
Owner's Guide
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/131781700ceen.pdf
Operating Instructions
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/131919500e.pdf
Cutout Dimensions
http://www.frigidaire.com/products/images/documents/cutout_dimensions/lc.pdf
Energy Guide
http://www.frigidaire.com/products/images/documents/energy_guides/134089300-USA.pdf
Feb 18, 2014 | Frigidaire GLET1031 Top Load Stacked...
I have a Frigidaire front loading washer, model FTF530FS3. The dryer that is stacked on top of it just quit. I have discovered that the new model of the dryer for this type, now called Affinity is slightly...
I would bet the manufacturer has an adapter for just this kind of problem. I did an installation on a stacked unit with a similar situation and there was an offset angle piece that attached the base of the dryer to the top of the washer. The front had a molded plastic piece to allow the dryer to rest on the front of the washer. Hope this helps
Oct 18, 2013 | Frigidaire FEQ332E Electric Dryer
Can an frigidaire X091307954 dryer be stacked on a Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer?
this is possible, youll need a kit that sets on top of the washer,check back where you bought the washer and dryer, they make a washer and dryer combo thats one peice, they are smaller however
Jul 13, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
I'm trying to disable the safety on the top load fridgidaire washer because it keeps malfunctioning and not finishing the rinse cycle.
This is something that is designed into the feature of this combo stack unit and cannot be bypassed at this current time - from my research.
Dec 24, 2012 | Frigidaire FEX831CS Top Load Stacked...
E-27 blinking
The E27 code isn't often listed in Bosch manuals but relates to the washer door lock.
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
You may need to replace the door lock assembly on the washer.
Jul 20, 2011 | Bosch WFVC6450UC Front Load Stacked Washer...
Kenmore 417 44042400 Front Load machine Sears says does not exist
YOU ARE ABSOLUTELY RIGHT. THE COMPANY SHOULD HAVE KNOWN ABOUT THIS. HERE IS MY SOLUTION: GO TO LOWE'S HARDWARE AND BUY A WASHER AND DRYER THERE. BUY THE GE BRAND. 3 YEARS AGO, WHEN OUR MAYTAG WASHER DIED, WE BOUGHT A NEW GE WASHER BEFORE MY FATHER DIED IN 2006. BUT CHECK INTO THAT. MY E MAIL ADRESS IS CoolRod41@yahoo.com IF YOU FIND THIS IMFO HELPFUL. GOOD LUCK.
RODNEY
May 17, 2009 | Kenmore 43042 Front Load Washer
Removal of front panel of a stack washer and dryer mod
Their are screws between the washer and dryer. Undo those and the screws inside the dryer, next too and below the lint trap.
Jan 17, 2009 | Maytag LSE7806A Top Load Stacked...
Rack for washing & drying machine
There is no rack available to stack this washer and dryer that I am aware of. Certain front load and portable machines can be stacked otherwise it is stacked from the factory.
Jan 11, 2009 | Maytag Performa PAV2200
My Maytag Front load stack unit washer/dryer model # MLE2000AYW
I had a similar problem, My washer spun but the clothes were still soaked with water. We replaced the inertia switch. That solved it.
Dec 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
631 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
