Hi,I had a power outage and when power was returned,I could not get my Mitsubishi rear proj 58" to turn on...all I have is a fast blinking green led that says timer...I tried the reset button and also pulled the plug for a minute to no avail.any ideas?
  • 108 Answers
If the like does not pause for a second or so then resumes blinking then you most likely have a defective DM Module. If it does pause for a second or so then you most likely have a problem with the siganl pcb or power supply. But in this case i would suspect defective capictors in the DM Module.
Posted on Jan 08, 2009
I TOOK APART THE TV TO MOVE IT DOWNSTAIRS AND it worked great for 10 minutes and then shut down. I have the code and it is green and 2 and 2
That is called the "Parpadeo luz verde de la muerte" or Blinking green light of death. You may want to make sure all the wires are tight first and that when you moved it a cable wasn't seated. Instead of replacing the capacitors, your situation sounds more like bad solder connections on the DM module. Here is a link to a web forum where they talk about this exact problem.http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens.html Blinking Green Light of ***** frequent prob Mitsubishi rear proj...
Jun 25, 2015 | Mitsubishi WS-65413 65" Rear Projection...
I have a 60 in. mitsubishi hdtv. i just got it and the tv wont turn on and the green timer light kept blinking. now the green light wont even blink. thank you
Send an email to Paul on this Hi Def forum and he will send you detailed instructions for repairing your set inexpensively. Hope this helps
http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens-5.html
Jun 01, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Green timer light justs blinks and the tv will not come on
I have a Mits rear proj screen ws-55613 replced the 4 caps on the DM and still have th fast blinking green LED any Ideas?
Jan 03, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Power outage tv never came back on
Unplug connector zn under front speaker panel if it comes on with remote replace this part. If fails to come check DM caopacitors generally also cause this problem
Feb 07, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Blinking Green Light Mitsubishi TV
I had the power supply replaced, but didn't solve the problem. Turns out multiple issues were at play. Only thing that solved the problem was to the have the chassis pulled and rebuilt by Mitsubishi. If you are insistent enough they should do it for free, minus the labor for removal and re installation (approx.$300)
Oct 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Cannot turn on tv
it sounds like the power surge got past the surge protector and damaged one of the boards in the back of the tv. it may or may not be worth fixing depending on what you want to spend on it
Jan 08, 2009 | Televison & Video
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
http://servicemanuals.vstore.ca/
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green led on WS-55511
You have two different model numbers lisdted and they are both different repairs.
Jun 17, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
