Question about Whirlpool Duet GHW9150P Front Load Washer
Front door gasket whirlpool duet washer
Front door gasket is all moldy and underneath even worse how to replace I always leave door open after wash and run the cleaning cycle per manual
  • 1 more comment
  • cavern2005 Jan 09, 2009
    I have a torn boot and have purchased the replacement part, but now need to know how to replace it.
    Please reply to my email: deanlies@cox.net
  • satchamoe Jan 09, 2009
    What a coincidence - we started a load today and found a piece of the gasket had broken off ours as well. How involved of a repair is this? I'm somewhat handy - I've had to fix our other KitchenAid an Whirlpool products - but would hate to get into something over my head or patience.
  • pzarnold Sep 16, 2012
    I found the answer to replacing the torn boot herehttp://www.fixya.com/support/r3574186-in...
    Sergeant:
    Champion:
  • 262 Answers
Before replacing run a empty load with alot of bleach in it and then clean boot with a mold cleaner like kitchen cleaner w/bleach replacing the boot isnt something you want to do unless you have to do it (not easy) and the cost of the boot if you need any more help let me know and i will guide you thru the process of the boot
bill
Posted on Jan 08, 2009
  • pzarnold Sep 13, 2012
    Bill, I got the boot off but now I'm trying to get the new one on. Is there a trick to doing this? I can't seem to get it lined up with the metal and then get the first wire on.
Moldy smell in clothes, especially towels
need to clean the bellow ( rubber around door). theres a tablet you can buy called "Affresh". It will help to remove the moldy smell. just throw it in washer and run through a regular wash cycle. no clothes, just the tablet. If there is a clean cycle on the machine then use that cycle. Whenever you're finished washing, you should leave the door open for about 20-30 minutes so unit can air out. Also you should wipe around the glass and bellow after each use.
Mar 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer not washing leaving stains on clothing
It sounds like the silicone apron between your washer drum and the door has deteriorated. If that is the case, no cleaner will help you.
Best solution is to order a new one.
Jul 31, 2010 | LG WM2455 Front Load Washer
I have always had a smell coming from my duet washer. I put bleach in and run it through a rinse cycle, but it always comes back
there may be some dirt or other things collecting in the drain boot attatch to the drain pump there is usually a plastic coin trap located inside the rubber boot his will cause a musty smell in the washer.as well as a moldy door boot seal.if the door boot is moldy it needs to be replaced.
Jan 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
Jan 03, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Moldy smell always tried bleach and vinegar. Use
You need to replace the rubber gasket around the front of the door. This gasket holds moisture and over time molds. Give us a call or email us and we;ll be sure to get the correct gasket out to you right away. We hope this helps and we hope to hear back from you real soon.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mold in door gasket between door and drum. I have washed it with bleach, will that be enough? I have also cleaned the soap dispenser and dispensing area. Is there any other place the mold could hide that I...
not really but when completed a wash cyc always leave the door open until it cools down, yes this applies e en if you wash in cold water todays modern front load washer mixes both hot/cold
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Odor in clothes
run an empty load in the washer but add 3 cups of vinager and set the washer to hat wash, this will help kill the smell, After you get done running it leave the door open this will stop it from happening again
Jul 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine odor
www.affresh.com this product has been devoeloped to lessen front loader odors. you NEED to be using an HE detergent. low sudsing ans specifically design for use with front loading washers.
Oct 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Stinky laundry
if that's a front load washer your only supposed to use an he detergent designed for front load machines others can build suds that when they dry can cause odors also its recommended that you leave the door cracked when the washer is not being used
Jan 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
700 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
