I have a samsung pdp42 built in 2002 it seems to overheat? and tuen off on its own. It may work for three hours or as little as 15 minutes. several of the capacitors have plastic ends that are bulging but when removed the metal of the cap looks okay? Any idea's?
  • 86 Answers
Yes, I can tell you that when the capacitors start bulging the you will need to replace the device. This is a sign that the capacitors are starting to fail. Now if you can put in a fan somewhere that will kept the heat down then you might be able to use it a little longer. You have got to get the heat away from the mother board.
Posted on Jan 08, 2009
My 2002 Altima SL 2.5 drives and shifts fine for an hour or so. Then it won't shift from first gear.
In spite of what Firestone did it still sounds like you have a defective speed sensor. Other people have also had this problem and it was solved by replacing the speed sensor.
I hope it resolves your problem.
Sep 22, 2014 | 2002 Nissan Altima
2002 ford explorer will not start sometimes battery is ok turns over starter is ok it is cold now starts ok in morning drive for about 15 minutes stop car for 1 hour 15 minutes come out to start car does...
Possible fuel pump. Check the fuel pump pressure;or remove the air intake hose from the throttle body.spray some gas with a squirt bottle in thratle body. replace the intake hose and crank it; if it turns on, your pump is bad.
Mar 27, 2017 | 2002 Ford Explorer
SAMSUNG --MODEL# DV3C6BEW/XAA NOW COMPLETELY SHUT OFF. CAN NOT TURN ON OFR OFF EARLIER -NOT HEATING PROPERLY, TAKES A WHOLE DAY TO DRY CLOTH.. IF YOU SET DRYER TO 60 MINUTES, IN 15 MINUTES, IT...
dryer has a restriction in the venting process; disconnect vent hose and run dryer should work, if not then you will need to take apart and clean out all the lint inside the dryer.
washer:
http://www.ehow.com/how_4910369_troubleshoot-washing-machine.html
Jan 11, 2011 | Samsung Dryers
The hot water recirc pump in my new house was equippped w/ this timer. There was no user manual, but it was set by the installer to run the pump during awake hours and shut it off during sleep hours. ...
1) Open link below so we are talking about same type of household system
http://waterheatertimer.org/Water-heater-recirculation-system.html
2) 15 minute interval is misleading.
Pins located on timer dial divide 24-hour day into 15 minute intervals.
You set timer pins and decide which 15 minute intervals you want ON-or-OFF. Do this by moving pins inward or outward with your thumb or ink pen. To check settings, manually rotate timer dial clockwise and listen for pump turning on-off..
Set timer pins for 4 consecutive 15 minute intervals, then timer runs for 1 hour.
After pins are set, then manually rotate dial to set current time.
Dial rotates as time passes, and pins click a lever that turns pump on-off.
3) 5-year Life span. Like all things plumbing, if you have hard water or sand-n-dirt in water lines, then pipes clog. And pumps clog.
Once motor begins to slow down, it overheats and burns out.
Water softener can keep sediment out of lines, but shortens life of water heater.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
4) Real question: do you need a circulation pump? Do you need hot water at your faucet? Can you schedule hot water use, or does recirculation pump have to run several hours per day?
Recirculation pumps causes water heater to run more, the pump consumes 25+ watts depending on pump, and water savings claims of 15,000 gallons per year are fabrication.
Realistic water savings is 700-2000 gallons per year, assuming several folks in the home use water sporadically across a full day, and each time water is used people are waiting for hot water. It also assumes that you never want cold water at the tap and that refrigeration ice maker line prefers hot water to cold.
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on pump/timer or any do-it-yourself project.
We are always less expensive than a service call.
Dec 18, 2010 | Taco 265-1 / 563-2 Combination Analog 24...
GE Spacemaker Microwave not working
Hopefully not!. Microwaves have a failsafe circuit built in that when they overheat they shut dowen for about 3/4 hr in severe cases and then reset themselves.
By now it has probably come back on line.
Please rate my help++++Thankis for using FIXYA
Jun 12, 2010 | Microwave Ovens
After installing windows 7 on my hp dv4 laptop I am getting an intermittent screen blip or flicker. I have a built in ATI radeon hd 3200 graphics card. I have donwloaded new drivers but doesn't seem to...
it sounds to me that you may be having gpu (graphics processing unit) overheat issues when your computer overheats the first thing that happens mostly is the screen my flutter or shake a little you may want to have your laptop cleaned inside out and this will help your problem just make sure that your monitor is not bad because this to will cause the same problem ! i hope this helps!
Dec 22, 2009 | HP Pavilion dv4000 Notebook
Miele Red Star Powerhead overheats and turns off
be sure at 1st there is no materials blocking the hose then it seems to me your m/c is good if normall condition around
try to test your cleaner by use less length hoses
thanks
Jul 04, 2009 | Miele Red Star Bagged Canister Vacuum
Tv switches off after 5 mins
There might be three or more reasons for this:
1) The sleep timer may be on causing the TV to turn off after a preset time.
2) If sleep timer is on and no signal from the remote is received for a preset time (Samsung: 15 minutes) the tv will turn itself off.
3) The TV may have been turned on automaticaly with "On Timer". If so, and no signal is received for a preset time (Samsung: 3 hours) the tv will turn itself off.
4) A fan is not working or a vent is blocked causing the TV to overheat and turn off.
For 1) thru 3), go to the "setup" menu and make sure "sleep timer" and "On Timer" are turned off.
May 09, 2009 | Televison & Video
TV SHUT S ITS SELF OFF
Is the unit free of dust and debris from dust? If its overheating there are may factors that play in this
1. fan spinning but not enought RPM rotations per min ( not fast enough)
2. room temp
3. dust
other then that some capictors must have exploded inside withc will cause a overheat.
Apr 22, 2009 | Samsung HLR5064W DLP Projection TV
Projector keeps turning off
When i turn the projector on it only comes on four about a minute until the temp lights go amber and it turns off, the fan is working but the air coming out is a little warm. what if anything is making my projector overheat, or is it not heating at all?
Aug 07, 2008 | Dell 2300MP Multimedia Projector
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
